Old 04-06-2020, 03:26 PM   #1
Pinchlite
Drives: 2007 yaris HB
Yaris dead.
Ran fine this morning.Battery is tip top but nothing happens when I turn key.No noises or clicks period.Only thing that comes on is dash lights,oil symbol etc.
Bad starter perhaps?
KSIbucky fixed it with 2 new fuses but he does not mention which 2 fuses
https://www.yarisworld.com/forums/sh...501#post829501
I tried boosting and nada.So battery is fine.
Bridged the clutch safety switch and no go.
Anyone have any ideas on what fuses KSIbucky was referring to?
Everything else works,wipers,mirrors,domes,radio,indicators,headli ghts,rear wiper/washer etc.
Old 04-07-2020, 10:41 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Is it a manual? If so, maybe try bump starting it. That should let you know of it's the starter or not.
Old 04-07-2020, 11:13 AM   #3
Pinchlite
Going to try this as soon as i can find someone to help me push it.
I will report back.
So if it starts by bump starting then it is 100% starter?
Old 04-07-2020, 08:42 PM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Check for loose battery terminals and blown fusible links under the red plastic cap on the battery. I was replacing an alternator once and shorted the positive terminal to ground with my wrench. No start, no clicks, nothing after that.
Last edited by CrankyOldMan; 04-07-2020 at 08:44 PM. Reason: added pic of fusible link block
Old 04-08-2020, 08:59 AM   #5
+1
Old 04-08-2020, 11:46 AM   #6
Pinchlite
Bad starter was the diagnosis.I bought a new one yesterday and installed this morning.He also noticed a loose rear wheel bearing as I asked him to tighten rear brakes while he had the car up.
Kinda glad I brought it to a shop because I did not notice the bearing was worn.
So know just waiting for something else to go.
Know to fix the low idle,almost stalling.
Old 04-08-2020, 08:27 PM   #7
Low idle is due to extended battery disconnect. The ECU now has to relearn your fuel trims. It will settle back in shortly. If possible, go for an uninterrupted 30 minute drive.
Old 04-09-2020, 12:15 AM   #8
06YarisRS
Glad to hear you got it fixed.
Old 04-09-2020, 10:05 AM   #9
Leegamer
Leegamer's Avatar
Nice! Hopefully you won't have any more issues. The only major issues I've had with my yaris have been water pump, rear wheel bearings, and alternator.
To get 180k miles out of a car with only those minor issues is pretty good in my book, though.
I'm a hermit named Lee
FS: Various Parts from a 2009 Yaris Hatchback Freestylin Items for Sale by private party 17 02-24-2016 10:36 PM
What is it about the Yaris Ranger SVO General Yaris / Vitz Discussion 18 01-06-2015 10:45 PM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 12:03 PM
Dead Yaris... (or at least severely injured..) 33OH Photo-Video-Media Gallery 45 11-15-2008 12:44 AM
