![]() Drives: scion xb Join Date: Apr 2020
prius c 1nz swap
this thread is a conglomerate from my postings on other forums, one of those is basically dead, and the other is non-public. also i have taken a fair amount of info from yarisworld. so you guys may find this stuff useful. long story short, i aquired an XB with a bad engine.
put in a junkyard yaris engine that did not live long. but i got to drive it about 2 weeks. rebuilt the original engine with prius c pistons and stuff but the original Cams must have been fractured from before i got it. they broke when i went to start that engine and before i figured out what happened it pushed metal through the second rebuild ruining it. instead of having the thing crushed, i stumbled upon a 200$ 3822 mile prius c engine. (now that you are caught up, continue) the installed cam in the prius c 1nzfxe is atkins cycle, the lobe is much more rounded and longer duration. the yaris cams will be going in. the springs are a different part number, but visually quite similar so i am going to leave the prius springs in place. i suspect the prius springs may have a slightly lower spring weight to them but i am not building a race car and theres only about 1000 RPM difference in the redline of the 2 engines so i am going to run it and see. (typically i would change the springs out, but i am getting tired of tossing money into this pit so this is getting a try it or take it to the crusher last ditch effort) other minor differences like no waterpump, no alternator bracket (it would have been on the waterpump mount) and watercooled EGR, as well as slight differences in the belhousing mount. nothing that i think cant be remedied. (the prius C engine was dumb cheap, if i can sell the prius c waterpump the engine will have been free.) benefits: this prius c engine had 3822 miles, comparatively the yaris and other 1nz junk yard engines are 100k plus. My last rebuild was hampered by used cams and i do not want to do a real full rebuild for a 2500$ vehicle. the electric waterpump should free up some horse power, i can not use the toyota one as it is connected to the prius ECU. debating how to handle power steering and alternator. at a casual glance it looks like the power steering pump will bolt up, alternator will need a little work. rebuilt and went to start the engine: power steering pump does not bolt up with out custom bracket. (not an issue for yaris people) i gutted it and made the xb rack manual. could have used an echo rack, or a MR2 electric pump, or converted to a yaris rack and electric motor assist, however i am a cheap bastid. alternator needs custom bracket. had to swap the lower case to accommodate starter location, A/C, and help make it easier to bolt the transmission up. waterpump = davies craig aftermarket EWP. TODO Engine Mounts Energy urethane. the scion mounts are the same as the 04 body style yaris so if you need mounts use those. the next body style yaris (07) you can mount 2 of the scion mounts in the roll stops if you have a press. besides some cosmetics, the yaris 1.5, 1st gen XB, and echo, are virtually all the same cars. fixing post, check back soon Last edited by Zedicus; 04-22-2020 at 02:57 PM. |
Following
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
^^^ Ditto...
Prius C motor mounted in the 1st gen XB with the scion xb transmission.
2012 Prius C engine. 2006 Scion XB. i do have the alternator mounted (NOT where it is sitting in the pic) , for some reason it may need slight shimming. just eyballing the belt path and it seems to stick forward about 3 MM. unsure shy, as the bracket i made follows the line from the front engine case. nothing a washer can't fix. i also have the Davies Craig EWP mocked up. it will basically go where the Prius C EWP was and i really only had to cut up the OEM hose to make things line up. i did have to add a section of 1/2" return coolant line to go from the heater core back into the pump. i am hoping to be doing final install on the Davies Craig EWP this weekend so i will finally have some more pictures. once that part is done it will be on to test fire. (crappy update i know, more to come though, sorry) |
davies craig EWP test fit.
intake test fit with alternator and ewp. a look down in and the top just have to hook up all the sensors, the wiring for the EWP is partially complete, getn close! |
i am a stones throw from test fire. it was midnight when i stopped and i still had to shower and be at work first thing in the morning.
TODO: airbox install add upper coolant temp sensor for EWP finish wiring EWP controller after test fire: install axles test drive after test drive: detail this pig, its gross. engine install: Dash pod for EWP: |
i drove it around last night at midnight. Prius C engine with Yaris cam, there is a NOTICEABLE seat of the pants power increase. i think i could easily keep up with the local civic kids. Also, as i had hoped, loosing the power steering is unnoticeable at all but a dead stop.
just another engine bay image. the plastic cover that is included with the scion XB would fit perfectly in its OEM location. i do not like the plastic cover and i think the engine with the aluminum valve cover and COP ignition looks better with out the cover. interior still needs work. i have a alpine head unit out of a late model Scion to mount. yes, the EWP controller wires are just stuck into the stereo harness at the moment. like i said, it was midnight and i wanted to drive it for proof of concept last night. While this seems like it is all but done, i did run into an issue. my home made flange has a pinhole leak in the weld when the engine heats up. so i need to yank the intake and my flange and get that fixed. still, this is a success. quick list of mods that i can remember: fidanza flywheel exedy clutch disk energy engine mounts davies craig electric water pump (the only required part for the swap) 2012 prius c engine with 3822 miles yaris OEM cams to remove the atkins cycle yaris fuel injectors (has updated spray pattern, do not use the prius injectors) nylon shifter cable bushings various gaskets and suspension bushings while it was apart. there is again a good performance increase while doing NO horsepower mods to this. it is on the OEM intake and air box, OEM exhaust. if i was doing this build for a customer i would use a MR2 electric power steering pump just to keep the OEM steering feel. |
super rad.
0-60 in slow
Drives: light blue liftback Join Date: Aug 2009
Throw some 100 in it, you'll see a big difference. I also found it kind of interesting that with no cat the exhaust had no smell as well. Keep an eye on oil consumption though, getting the rings to seal at higher rpm's is a issue.
2014 BSpec Divisional Champion |
2ZR swap. DO IT! Ask how!
Crazy!
Did you consider an electric power steering assist from a current gen Yaris? You'd have to add the wiring to power it and possibly fabricobble the mounts, as well as spoof the speedo sensor to deal with the speed-based assist level. On second thought, that seems like more hassle than it's worth. =) |
#11 | ||
thanks
0-60 in slow
Its more to do with how low tension the prius C engine rings are, its just something to keep an eye on didn't seem to hurt power all that much. On 91 it would still hit the knock sensor so 100 made that not happen, a whole lot more torque midrange between the two. Don't run avgas its got lead in it and it'll cause problems with your O2 sensors. If you're in Kansas try running 93 if you can find it.
the 1nzfxe from the prius C is 13:1 compression?
#14 |
13.4:1 actually.
for clarity, the prius c engine has pistons that are 13.4:1. the atkins cam makes the engine around 8:1 dynamic comp depending on vvti. moving to the Yaris cams moves that up a lot. i figured dynamic comp of prius c pistons with yaris cams to be 11.8:1 - 12.6:1 through the vvti range, give or take. so even premium 91 oct is a little low for max performance, but the knock sensor and ECU can keep premium within acceptable. running low grade gas in this setup would be detrimental to engine life. previously i had actually swapped prius c pistons and rods into a bone stock yaris engine and ran the Scion cams. that combo had a little better torque curve. i believe that since the toaster is more box like, it uses a torquier cam. if you follow along up top, the scion cam is the one that broke so i moved this build over to the yaris cams i still had. Last edited by Zedicus; 06-17-2020 at 02:26 PM. |
#15 |
i spent a day buffing and detailing, and i dropped the newer head unit in. i wish this site supported bigger pics, but still if you look at the reflections and headlights it is pretty obvious. i still need to get the USB port and bluetooth installed, and sub and amp. but still progress.
shiny on the outside. not gross on the inside. EWP controller looks like it belongs there. |
#16 |
i have put about 200 miles on it and so far all is well. considering i had the entire rack out and the front end all laying on the floor, the alignment is only a little off. i will be getting an alignment this week.
the accessory belt now only drives the alternator and air conditioning compressor. the belt path meant some small adjustments had to be made and also, there is about 1/4th the contact area on the a/c compressor as before so belt tension is critical. so far my modified alternator bracket and adjuster seems to be doing its job. sadly, my 30$ alpine head unit has a bad USB port (the single feature i wanted it for.) i pulled it apart and tested the port and managed to get it to connect to USB briefly, but it seems to be more deeply broken then i care to diagnose so i will be doing something different here. i ordered replacement keyfobs, and i am still tidying up loose ends. and now that it is shiny, there is clearly a name keyed into one of the doors. also, the top of the body is sunburned beyond being able to buff it out. debating painting or plastidip up there. this thing clearly had zero maintenance from its previous owner. and the C50 manual transmission seems to have butter soft synchros. the ones in this transmission are all but vaporized. luckily i learned to drive manual in old pickups and dump trucks so rev match and heal-toe is fine for me. (the gas pedal is a long ways from the brake in this thing). but at some point i may have to address the tranny. |
#17 |
Status update:
the American alternator tensioner bracket just does not work in this configuration. i tried 3 times to turn it into a vertical and linear adjuster. while mechanically, it is possible. the strength of the item makes it not work long term. i broke it 3 times and even after welding in added strength, it would just break somewhere else. so i replaced it with the world spec part, it is listed on this forum as a alternator bracket https://www.yarisworld.com/forums/sh...ad.php?t=25758 and i modded it slightly to add vertical tension. so far it is working fine. time will tell. the other issue, even with 91 octane gas, this car makes too much power. (such a terrible problem) it has pretty much eaten a brand new stage 1 clutch. i am probably going to have to install a ceramic fiber disc and heavy duty pressure plate. (stage 2.5 or 3, for the tuner crowd) and last note, i was correct in assuming that losing power steering would be a non issue. while it is noticeable when in a parking lot, it is not much of a difference even then. The mechanic i had do the alignment even said he only noticed when he was at a dead stop trying to turn the wheels. final thoughts: while i would say this is a success. i would not recommend just randomly swapping to the prius C block unless you need at least a bore job on your current block. that is about the cuttoff for it being worth the effort to swap in. OTHERWISE i would recommend swapping to the prius C rotating assembly, and Scion XB cams. that combo gives a noticeable power bump with the biggest hit in midrange. the combo i am currently on is prius C complete engine with yarris cams, the biggest increase in power with this combo seems to be in the upper RPM range. it is still pulling substantially up at the 6200 RPM redline. i have not attempted a ring out run to see how far it would run out, i suspect that since it is manual, there is no actually limiter. as such it would just run till valve float and knowing my luck the higher comp pistons would smack a valve. with the electric water pump, no power steering, cams, and high compression pistons i fear i am putting 130HP to the wheels. this is on stock exhaust and intake. i make trips to denver a couple times a year and i am going to try and get it to a dyno shop one of these days for verification. Last edited by Zedicus; 10-20-2020 at 01:19 PM. |
#18 |
Amazing thread! Impressive work!
| Prius Piston swap in 1NZ (update pls) | rabbito | Performance Modifications | 2 | 06-12-2016 10:18 PM |
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 08:11 PM |
| Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c | Yar Is Word | Third Gen Yaris General Discussion | 27 | 09-06-2012 11:37 PM |
| Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> | jay cobbs | General Yaris / Vitz Discussion | 8 | 06-07-2012 01:44 PM |
| Toyota says don't call them Priuses -- call 'em the Prii | Kal-El | Off-topic / Other Cars / Everything else Discussions | 7 | 02-22-2011 10:30 AM |
