Old 04-24-2020, 10:04 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Oil Change on the Turbo Yaris
Covid-19 isolating has given me time to work on my car, and do lots of posts including such basic things as oil changes. Hopefully. it's not too boring. Getting the car ready for spring. Although there was probably less than a couple thousand kms on the oil, I figured I'd change it out. I live on the edge with this car, so it does get extra maintenance.
After reviewing tmontague's posts on oil, I decided to go with the 5W20
While doing the oil change, I checked all connections: turbo piping, turbo manifold and downpipe bolts/studs, oil feed, drain, turbo coolant hoses and all connections and hoses for the transmission cooling tubing, sensors and cooler etc for leaks as well as checked piping clearances etc. I did a lot of rustproofing while I was under there too.
One minor thing I found...
Old 04-24-2020, 03:06 PM   #2
Nice. I took this time to change the coolant on my Yaris yesterday since it's past 100k miles.
Old 04-24-2020, 08:34 PM   #3
06YarisRS
Ah ha. That reminds me. I should do that too. I think my current coolant only has a couple thousand kms and about a year on it as well. It's probably fine, but I do like fresh fluids in the spring. Brake fluid flush is slated for tomorrow, unless I get diverted onto restoring the new (used) set of wheels I picked up today.
Old 04-26-2020, 04:35 AM   #4
Yeah, I wouldn't bother with the coolant if it's that new still.
Brake fluid is something most people don't ever change or even look at. What do you use? I like DOT3/4 (Amsoil brand for me). I've tried Torque RT700 (DOT 4), but it didn't last long before starting to absorb water...but then again, I think the shop I went to botched it up (actually, a couple years later, admitted to it, but that's another story). Figure, the one time I let someone else work on my car...
Old 04-26-2020, 12:51 PM   #5
woops
Drives: Jeep Cherokee XJ 1996
Good job but sir, please get a pair of proper jackstands, infact get 4x of them, they are cheap - reliable and small enough to not take too much space.
woops is offline   Reply With Quote
Old 04-26-2020, 10:14 PM   #6
06YarisRS
Thanks. Actually I do have 4 jack stands. A couple of them are 5 ton stands. My car lived on them while I did the swap and then the turbo kit. For quick jobs like oil changes, inspections and trans fluid drain etc. I just jack up and block under the tires with 4 x 4s. Normally, I would crib two levels of three blocks for a total of 6 per wheel, but this time I only used 4, each side. Even if the jacks failed, the car would only drop a couple inches.
Old 05-22-2020, 07:37 AM   #7
06YarisRS
Sorry, I missed this. Yeah, I've seen some pretty dark fluid in cars that come into our school shop. I'm sure that a lot of brake jobs (caliper replacement) could have been avoided even with very occasional brake flushing. I just use SuperTech (blue bottle) DOT3.
I totally get doing your own work. It's not always that techs are not skilled, but probably a little more cavalier as it's not their own personal vehicle. Even dealerships I've talk to will often use un-approved fluids. I'm still surprised when speaking with dealerships that they don't even always use their stocked OEM fluids. I was speaking with Kia and VW about what's involved in their transmission fluid replacement and they use a universal fluid, Wynns or something. I would actually have to 'request' that they use OEM fluid.
FS: COMPLETE turbo kit for yaris 0BD1Kenobi Items for Sale by private party 41 03-16-2016 12:33 AM
Used Oil Analysis - Yaris '08 144,000km tmontague DIY / Maintenance / Service 10 10-30-2015 01:26 PM
HKS turbo for mk1 yaris 1 litre 1SZ-FE nuttallacpw Items for Sale by private party 10 01-26-2011 06:03 PM
