Throttle body coolant lines
I have a small leak and it seems to be coming from around the throttle body area but can't really tell. Are those two lines under the throttle body the coolant lines? the ones that the red arrows are pointing to?
Yes they are. You can actually connect the two hoses together (with a piece of pipe in between) to bypass the coolant flow through the throttle body, if the leak is from the throttle body or its pipes. The only purpose of that is to heat the incoming air for emissions purposes.
cool
k, thanks you the MAN.
Hope much of an intake temperature difference would it make when bypassing?
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
I can only talk about the 1KR-FE, but I had 5...15K above ambient temperature, even with some kind of cold air intake.
![]() Drives: Toyota Vitz 2007 (1KR-FE) Join Date: May 2020
Isn't that for anti-ice purpose of the throttle valve.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Installed the 1zz throttle body - | AlexNet0 | DIY / Maintenance / Service | 135 | 08-01-2014 07:57 AM |
| Cleaning throttle body | ToTo | Performance Modifications | 18 | 07-27-2011 05:20 PM |
| How to throttle body coolant bypass? | kliwonz | DIY / Maintenance / Service | 0 | 05-24-2010 12:50 PM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
