![]() Drives: 2007 Toyota Yaris Join Date: Apr 2018
Can anyone point me to a replacement clip for the vent hose on a 2007 Yaris?
This clip broke while replacing the fuel pump. Tried taking it to Autozone and the parts specialist at ToyotaPartsDeal.com, but none of them could ID it, and I couldn’t find anything in the service manual. Anyone have a part number or know where I can get one? Thanks!
Knower of little
Drives: None Join Date: Jul 2019
Dorman HELP! parts should have it. It's just a fuel line retainer, usually when you buy a new pump it comes with new ones, so it shouldn't be too hard to find. You could also potentially create something else to do the same job. If you look on the neck that the hose snaps onto, theres a slot that the retainer latches into. All you'd have to do is find a secure way to jam the line from popping off from pressure.
On second thought it should be a very similar if not an identical part across the toyota line, so I wouldn't rule out parts that don't explicitly say they don't fit your model, as long as they at least fit toyotas of the same age. |
I did some googling and all I can say is Toyota parts illustrations suck.
Maybe this?
https://parts.toyota.com/p/Toyota_20...724160320.html https://parts.toyota.com/a/Toyota_20...1470-7701.html Possibly P/N 7724160320
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 07-31-2020 at 09:36 PM. |
#5 | |
#6 | |
https://parts.toyota.com/p/Toyota_20...720952101.html If it's not, could you not find a piece of suitable diameter wire/soft bendable aluminum rod or such and make a "U" shaped clip. I assume the clip is designed to keep the hose from backing off under pressure? Then again, you don't want fuel spewing around under your back seat.
#7 | |
https://parts.toyota.com/p/Toyota_20...740452050.html |
#8 | |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Yaris 2007 (UK bought) Key Fob replacement | sdfsdfsd | General Yaris / Vitz Discussion | 4 | 01-25-2016 05:44 PM |
| Toyota unveils 2007 Yaris T-Sport Concept | VitzBoy | General Yaris / Vitz Discussion | 63 | 01-21-2007 03:12 PM |
