Old 08-01-2020, 12:31 AM   #1
namikaze
Drives: 2010 Yaris HB
New fuel pump, fuel gauge showing full
I have a 2010 Toyota Yaris hatchback that won't start. The engine cranks but doesn't turn. I had a mechanic look at it and he mentioned that the fuel pump was bad.
I decided to tackle this myself to save some money. I bought the whole fuel pump assembly listed below. But the car still doesn't start. I also do not hear the fuel pump priming. Before I replaced the pump, the fuel gauge was reading empty now it reads full. If I unplug the pump, the gauge still reads full. Fuel gauge also shows full when I plug the original fuel pump assembly in.
Any suggestions?
https://www.rockauto.com/en/moreinfo...pR8Nc7JG51vd3b
namikaze is offline   Reply With Quote
Old 08-04-2020, 11:59 PM   #2
namikaze
I pulled and replaced the fuel related fuses and now the fuel gauge shows that the the tank is empty. I put in at lease 4 gallons of gas in so I know it's not empty. I'm guessing this fuel pump assembly might not be compatible.
2007 sedan fuel pump not running and check engine light nitrus10032 DIY / Maintenance / Service 23 08-23-2025 01:09 PM
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 326 02-15-2025 11:09 PM
Could an improper seal on my fuel suction assembly be causing these issues? ThrowingChicken DIY / Maintenance / Service 18 04-14-2018 04:44 PM
Fuel gauge says 1/4 but tank is empty Shinare DIY / Maintenance / Service 19 04-09-2018 08:39 PM
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 09:55 PM
