Maintenance not in the owners manual
Battery corrosion. Some batteries corrode some don’t. It’s caused by battery acid gas leaking around the terminals. Whenever I get a car first thing I do is grease the terminals with wheel bearing grease. But you still have to check periodically unchecked you can have a real mess and a no start. If there is corrosion baking soda mixed in a pot of hot water and a wire brush will scrub it away. Then you can reapply the wheel bearing grease
Yup. I've seen a lot of nasty looking battery terminals. Definitely should be part of the routine maintenance schedule.
Fluid Film is good for the batt terminals.
What’s that?
| Owner's / Service Manual | tyrone_yaris | General Yaris / Vitz Discussion | 3 | 01-30-2012 12:02 AM |
| For Sale: 1993 Honda Civic Si 2dr Hatchback 5sp Manual | Effizienz | Cars for Sale by private party | 9 | 01-17-2012 11:08 AM |
| Warranty Information for US Yaris Owners | AdeJong 03 | General Yaris / Vitz Discussion | 4 | 09-19-2009 10:14 PM |
| Yaris 2002 - Owner's Manual | abhinav_kr | DIY / Maintenance / Service | 0 | 08-20-2009 11:49 AM |
| C54 MANUAL TRANSAXLE service manual needed | ricepower | DIY / Maintenance / Service | 1 | 08-29-2007 07:24 AM |
