![]() Drives: 2018 3dr auto 1.5 Join Date: Sep 2020
2018 1.5 auto upgrades?
I bought a nice, used, 2018 1.5 auto 3dr. I LOVE the car, but...... she's a little slow...
Now I'm not looking to put car lengths on a Supra, just want a few bolt ons. Something thats a good "bang for your buck", and most importantly... NOT void the warranty lol |
Yep
Drives: 2015 Yaris 1422 Join Date: Feb 2016
Realistically any bolt-ons (intake, header, exhaust) won’t make it much faster.. but it will make it seem faster and a lot more fun to drive.
As to what’s available.. someone else with more knowledge of the newer models have to chime in. |
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
First mod should be a manual swap.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
I said not void the warranty lol Plus I'm disabled and just walking with my leg hurts much less pushing a clutch pedal.
I decided on a intake (just for sound, because the little 1nz does sound nice at high revs) and a 2ZZ throttle body to get rid of the WOT from a stop problem (the problem being, the car will not go WOT from a stop no matter if pedal is to the floor or not. Even with TC off. Its the most annoying thing about this car lol |
#5 | |
Gen 3 > Gen 2
![]() ![]() Drives: 2015 Toyota Yaris LE Hatchie Join Date: Oct 2021
I feel ya on the automatic. It does seem to shift early/ low RPM. I imagine that it is computer controlled.
Sifting shift points with a sport button would be nice. Does the SC have a "sport button"? Is it French Built? Would The hatch backs be pre wired for a "sport" button? I wish there was a manual for the 2015 up, but I have not found a chilton or a hanyes much less an FSM (Factory Service Manual). Oh gooruuzs of yaris give us lowly wrench swingers your wizdom! P.S. adding a "sorts" button would shred your warranty unless done by a factory authorized Mechanic and documented according to said contract. Then again most aftermarket bolt on stuff would do the same if I remember correctly. Besides isn't it 3/36 for a yaris. Any ad-on warrantees would gut you in the fine print for ANY MODS! Fly by wire would eliminate WOT unless you changed/ burned your computer/ chip! Last edited by Calrenman; 05-30-2022 at 03:05 AM. |
Mitch, I do not know if with a computer you could swap to a manual. The main control module would get freaked out when it realized it did not have a tranny anymore! No shift data or feedback from sensors... It would code!
Gen 3 > Gen 2
Get an ECU out of a same year manual Yaris. Problem solved.
Update: found another with my same issue. I'm not crazy afterall, the ECU is indeed limiting throttle to 80% max, and only 50% from a stop at WOT. This PLX device mentioned is cheap enough to try and seems to solve the "lag" issue but not the 80% problem. I'll be happy enough with that for now until I swap throttle bodies to a 2ZZ unit, which takes care of the issue altogether.
https://www.yarisworld.com/forums/sh...t=14476&page=2 |
#10 | |
Gen 3 > Gen 2
