Old 10-03-2020, 09:18 PM   #1
littleblackyaris
Drives: 2007 Yaris 3-Door
2007 - Water pump suggestions
Hi,
I have a 2007 Yaris 3-door hatch with about 127,000 miles on it. About 2 years ago, I replaced the water pump together with the head gasket. Now, the water pump is failing again, only about 30,000 miles later.
I'd like to know if Yaris fans have any suggestions for what to do next. Obviously, I'll be replacing the water pump. This time, I'll be supplying the pump myself rather than letting the shop put in a rebuilt one. I've read good things about the Aisin pump. Is that the pump I should buy?
Anything else I should consider before it goes to the shop? Should I use a lower-temperature thermostat, etc.? I want maximum reliability from this thing. Thanks!
littleblackyaris is offline   Reply With Quote
Old 10-04-2020, 09:51 AM   #2
ex-x-fire
Yeah, probably a bad pump. I have seen them fail at low or really high mileage. I'd go with an aisin pump, I'd keep the stock type t stat though, you could run into check engine light codes if it runs too cool.
Fuel filter replacement jaimico DIY / Maintenance / Service 43 03-07-2023 12:05 PM
water pump change 2sz-fe finnpoulsen DIY / Maintenance / Service 5 03-25-2020 11:20 AM
change water pump n something is shifting susucosp DIY / Maintenance / Service 1 10-04-2013 03:23 PM
Car shuts off when A/C turned on... Howster DIY / Maintenance / Service 33 07-06-2013 06:00 PM
coolant flush/ water pump jstantherprsn DIY / Maintenance / Service 26 10-26-2010 11:36 AM
