Old 11-04-2020, 10:11 PM   #1
camala
Drives: toyota yaris2008
yaris 2008 ac is not working
Hi, I have a 2008 yaris the ac is not working I check the the compressor the electronic valve was stuck I order a new one, when I take down the compressor to replace the valve I find out the compressor is defective (the oil inside was dirty and full of metal particles) I need to order a new one.
I have to flush the pipes and evaporator .
Q what solvent I can use to flush them ?
Q do I have to replace the condenser to? or can I try to flush it .
thanks in advance, need some help.
camala is offline   Reply With Quote
Old 11-05-2020, 06:53 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I replaced my condensor when I fixed my A/C system. They're pretty cheap. Also, with a new condensor, you get a fresh desiccant bag. I'd go for a new one. I assume you have a set of manifold gauges and a vacuum pump?
Old 11-05-2020, 09:03 PM   #3
camala
Hi, I order a manifold gauge and the vacuum pump I am building it from a use fridge compressor.
I am using white spirit to flush system
thanks for helping
5spd 2008 Toyota Yaris trade for auto yaris tengys Cars for Sale by private party 8 03-07-2016 05:04 PM
2008 Yaris YR Hatch, radio not working ? aleks001 In Car Entertainment + Electronics (audio / video / alarm) 2 03-18-2015 06:33 AM
New-to-me 2008 Yaris 3 door MT mittra New YARIS Purchase Forum 5 02-27-2015 03:21 PM
Quick Question about the 2008 Yaris: doog DIY / Maintenance / Service 5 11-29-2014 12:26 PM
