![]() Drives: daihatsu sirion Join Date: Feb 2021
Hi folks, newbie here - thanks for the great forum!
Hoping you can point me in the right direction. ![]() My wifes Sirion (Yaris T3 engine) has a strange issue where the fuel pump only switches on intermittently. Initially I thought it was the fuel pump, so I replaced the Denso pump and filter for a new Bosch unit. After replacement the vehicle started, idled, and did a long test drive without any issues, several test starts afterwards was also fine. The car stood for a few hours, when trying to start it again the pump wouldn't switch on. I'm still testing a theory whereby when I pull the EFI fuse for a minute and replace it, it allows the pump to switch on again (some sort of "reset"?) Is there perhaps another relay or fuse I can check that could be acting up? As part of the initial troubleshooting I checked the coils, spark, battery, fuses under the hood. I also disconnected the battery while changing the pump. Hope you can help! |
I've found this diagram for the internal fuse box behind the cubby, I noticed "Fuel Pump Relay" at the bottom left, so I guess it's worth replacing
Well I've replaced the relay for what its worth, still nothing :/
| Fuel pump, sender, seal, wiring, and cluster | mavrick | DIY / Maintenance / Service | 5 | 07-22-2019 05:34 PM |
| HELP: Swings but does not start after fuel filter replaced | REV 2 11 | DIY / Maintenance / Service | 12 | 08-19-2013 01:38 PM |
| Fuel Pump Relay | bronsin | General Yaris / Vitz Discussion | 4 | 08-07-2012 07:19 AM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
