Old 01-04-2018, 03:28 AM   #1
Cichu91
Drives: Yaris
Help with finding a firewall for amp power cable
Hello i have a yaris d-4d 2008 and i cant find a Good firewall or a hole where i can drag the amp power cable from battery.
Any suggestions or pictures on where to drag it?
Cichu91 is offline   Reply With Quote
Old 01-04-2018, 09:20 PM   #2
knobby bobby
knobby bobby's Avatar
Drives: 2015 Yaris Coupe
look toward the left closer to the top. There is a rubber plug. Pop it out and snake through.You will have to remove the glove box. squeeze together. pull out. be careful and make sure your power cable has an in line fuse and make a good ground for your amp and yur good 2 go.
knobby bobby is offline   Reply With Quote
Old 01-04-2018, 10:30 PM   #3
tmontague
tmontague's Avatar
On the left side at the top of the firewall is a large grommet about 1 1/2" in diameter you can use. For us NA spec'd yaris' it is behind the battery. Not sure if your battery placement is different
Old 03-12-2019, 10:31 PM   #4
Bikerboy89
Drives: 2015 Yaris Liftback LE auto
Hello is this in the same spot on the 3rd gen model 2015?
Bikerboy89 is offline   Reply With Quote
Old 03-13-2019, 03:57 PM   #5
Jeanseb29
Drives: Toyota Yaris RS 2011 (HB)
On both my 09 and 11 HB I got through the firewall on the passenger side from the interior by removing handglove box and panel below it and detaching the carpet from its highest position. To undo the clip attaching the carpet just take a flathead screwdriver and pop the middle of the clip. Find the black rubber grommet, make a X cut in the carpet in front of the grommet to get your wire trough. Remove the entire grommet and if you have big wire, cut the center with a knife and keep only the rubber"ring". If you have a tiny wire, take a drill and make small hole in the center without cutting it. Get wire trough ring and put ring back in the firewall hole. Use silicone if not completely sealed.
Jeanseb29 is offline   Reply With Quote
Old 03-14-2019, 02:57 PM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The 2nd and 3rd gens have the same body so the hole described by Jeanseb29 should still be there. That's how I brought the wires for the supercharger into the cabin when I had it installed.
Old 09-29-2019, 12:21 PM   #7
geo4st
Drives: yaris d4d 2013
I have a 2013 d4d and i really can't find the firewall, anoyne has photos? Thank you.
geo4st is offline   Reply With Quote
Old 09-30-2019, 09:00 AM   #8
CrankyOldMan
The firewall is the panel that divides the passenger compartment from the engine compartment. The hole we're talking about is about 2 cm in diameter and has a rubber plug in it. It's behind the wiper cowl, above the ECM, almost up to the windshield. You might have to remove a few parts to be able to reach it--wiper arms, wiper cowl, wiper tray. The hood can probably stay in place even though the repair manual says you should remove it for accessing that area.
You can also see it from under the dashboard but you have to remove the glovebox and peel back the padding a little bit at the top.
Old 09-30-2019, 04:22 PM   #9
geo4st
Thank you very much, my sub and amp arrived today and i was stressed about it, i know what it is but i couldn't find it, i will look for it tomorrow, thank you very much.
Old 10-02-2019, 06:04 AM   #10
geo4st
This is a photo behind the glovebox, where is the spot i have to peel off because it seems hard to do it so I have to cut it.
https://ibb.co/YyKG4dr
Old 06-15-2021, 02:24 PM   #11
croustian68
Drives: Yaris LE 5dr 2016 AT Blue
Follow
im at that place too i wonder what is the pink plastic pin and where it go. the clear tube is windsheild washer for back glass but it seem to go behind the shock tower not acces.. I want to know if i drill out a hole bettween the pink clip and clear hose where its gonna be in the engin bay cuz there some place to put decent seal tight connector.
croustian68 is offline   Reply With Quote
amp, amplifer
Running Firewall Power Wires for subwoofer MacMaster761 In Car Entertainment + Electronics (audio / video / alarm) 17 03-06-2010 03:04 PM
Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) gaffo General Yaris / Vitz Discussion 28 07-15-2007 07:55 PM
Need Help - Electrical (finding Power) Ayka DIY / Maintenance / Service 7 10-12-2006 11:51 AM
using regular power lock kits with cable style twixt DIY / Maintenance / Service 4 08-12-2006 01:18 PM
