Old 07-04-2021, 08:05 PM   #1
sv650steve
Drives: accord (for now)
Bad AC
My A/C blows hot. The shop quoted my $1900 for a new high pressure switch, metering device, evap coil, filter dryer, and compressor. It just started happening. I read pressure on the lowside and it was around 100 psig. I did not have the fitting to do the high side (i'll be buying that tomorow). There are no bubbles in the sightglass and it looks like the refridgerant is not moving.
Could I just buy the compressor, high pressure switch, and vaccume pump and hope for the best? Or should I replace the whole system like they suggested? A rebuilt compressor is only $400 and comes with a 2 year warranty.
sv650steve is offline   Reply With Quote
Old 07-05-2021, 10:16 AM   #2
When my a/c died, the dealership diagnosed "seized" compressor, to which I said BS. My pressure switch was the point of failure which I replaced with a unit off eBay for around $20.
Old 07-05-2021, 01:34 PM   #3
bronsin
bronsin's Avatar
What do you mean you don’t have a high pressure fitting? It’s got to be there someplace! Keep looking.
I am leery of the shop saying so many things are wrong
Old 07-05-2021, 04:55 PM   #4
I'm sure he is referring to the high pressure fitting for his test gauges, not the lack of the actual high pressure Schrader valve on the AC lines.
The shop wouldn't necessarily be saying that all those components have failed. I know for a fact that if a compressor is to be replaced, the manufacturer stipulates that some other components be replaced (ie the dryer) or the compressor warranty is void. Other parts in that list not necessary for warranty are prob just parts in an AC replacement bundle.
Old 07-05-2021, 08:00 PM   #5
ex-x-fire
I'd go to another shop.
Old 07-06-2021, 04:35 PM   #6
remcafee
if it really is a seized compressor, then replacing the whole ac system is the best choice, most of the time those ac flushes never work, have another look at it and make it is seized compressor, and not the clutch not engaging, cause ifyou do have a seized compressor, you already metal filings all throughout the system and youneed to replace everything
Old 07-06-2021, 07:19 PM   #7
bronsin
bronsin's Avatar
Looks like I was wrong!
Old 05-09-2022, 06:02 PM   #8
rodrigogar
Drives: 07 Yaris Sedan S
Hi WeeYari.
I found this post as I am troubleshooting my AC. I checked continuity for the pressure switch sensor (the one next to the sight glass and high side port) and there is none.
I am tempted to just replace it, however, wanted to ask you if when you replaced it there was a valve that stopped the freon from escaping, or the system had to be emptied in order to replace the sensor?
Thank you in advance for your time.
Rod
rodrigogar is offline   Reply With Quote
Old 05-12-2022, 06:00 PM   #9
I've no idea if it is valved. I had an independent shop replace mine. They were not able to find any info on there being a valve in place so they went ahead and discharged the system and recharge with my reclaimed coolant.
Post here if you learn of definite existence or absence of a valve.
Old 05-14-2022, 02:15 AM   #10
sh0rtlife
as ive just gathered EVERYTHING to put a system on a car without i can tell you said valve does not exist
"if" you genuinly have a seized compressor you "can" reclaim all the parts it just has to all be done with the parts OFF the car as you cant just flush it on car..it wont work especialy with the way the condensor is mounted
however with everything pulled everything can be flushed very easily at which point you can replace the pump and be done with it.
A bad start to the new year :( eTiMaGo Photo-Video-Media Gallery 69 02-17-2009 09:51 AM
Bad Driving Techniques Altitude General Yaris / Vitz Discussion 10 02-10-2009 06:26 PM
Bad luck this evening! Burningbjorn General Yaris / Vitz Discussion 11 01-16-2009 02:37 PM
Bad breath GeneW General Yaris / Vitz Discussion 7 01-16-2009 10:10 AM
REALLY BAD CAR ACCIDENT! MacMaster761 General Yaris / Vitz Discussion 25 11-30-2006 12:20 PM
