Old 06-28-2021, 11:08 AM   #1
ghowey
Drives: 2010 Yaris Sedan
ECM Harness Question
During a recent ECM swap I inadvertently broke the latching mechanism for the Body Side Harness. Is there a way to repair the latching mechanism short of replacing the entire connector (Ain't Gonna Happen!!)?
Thanks!
ghowey is offline   Reply With Quote
Old 06-29-2021, 10:27 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Pictures would help. Some parts can be replaced.
Old 07-23-2021, 09:59 PM   #3
ghowey
Hear are a couple of shots of the body side ECM harness where I broke the latching mechanism.
Old 07-24-2021, 10:20 AM   #4
CrankyOldMan
Good news, bad news. Good news is that it's entirely replaceable. The bad news is that it's a pain in the arse to remove the small pins. I just bought a tool from TE (Tyco/AMP) that's supposed to be designed for those and it's not very effective. There's a few other part numbers that I may try but they're really expensive.
Old 07-24-2021, 10:34 PM   #5
ghowey
The actual latching slides (maybe not the right term?) are in good shape and seem to hold stuff together pretty well. Maybe I can use a zip tie to assure all stays in place. Not really up to the task of changing the connector. More than likely if it is a PITA I will make the situation worse. Thanks for the info!
Old 07-24-2021, 10:53 PM   #6
CrankyOldMan
Always glad to help! You may find that it's still able to lock in place even with the broken hinge. The slides do most of the clamping.
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 12:56 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 04:54 PM
Quick deck harness question. Taiyaki In Car Entertainment + Electronics (audio / video / alarm) 0 03-09-2010 06:23 PM
Question on 09 Yaris Radio harness fresnoyaris In Car Entertainment + Electronics (audio / video / alarm) 4 05-04-2009 07:35 AM
