Old 03-10-2009, 02:25 PM   #1
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Hatchback, rear door trim removal
I can't find the info in the service manual. How is the rear hatch plastic attached? Where are the clips, etc. Anybody got a page number?
Old 03-10-2009, 02:56 PM   #2
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
start at any corner and just pull off carefully. you might mess up a clip or 2 but it is what is is unless you have a that tool to take panels off.
Old 03-10-2009, 11:50 PM   #3
Carpe_Diem
sells rhymes like dimes
Carpe_Diem's Avatar
Drives: 08 LB MM
Send a message via AIM to Carpe_Diem
i'd like to know as well. i have a HUGE dent in my hatch, and if at all possible, i'd like to remove the plastic piece to see if theres any way i can bang it out with a rubber mallet
Carpe_Diem is offline   Reply With Quote
Old 03-11-2009, 12:20 AM   #4
Sodium Duck
╚══════════RN
Anybody else?
Old 03-11-2009, 01:06 AM   #5
andru47
andru47's Avatar
Drives: 2009 Yaris 3DR LB
Send a message via AIM to andru47
I tired to remove the panel once, almost lost the clips to the door, had to use my fingers to fish out the clip that had fallen, let's just say my Yaris drew some blood that day. It is a real mess! Wish I knew an easier way to do it too. Will keep checking for updates!
My Yaris: The Azure
andru47 is offline   Reply With Quote
Old 03-11-2009, 08:33 AM   #6
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
If you plan on doing it more than once, invest in these:
http://www.amazon.com/Actron-CP5011-...=pd_sbs_auto_1
That's what the pros use.
Old 03-11-2009, 08:51 AM   #7
Sodium Duck
╚══════════RN
They almost seem worth it... Are they plastic? I'd be worried about scratching/chipping paint and plastic if they were metal.
Old 03-11-2009, 08:56 AM   #8
Sodium Duck
╚══════════RN
Grrr, this is annoying. I just went through the entire interior trim section of the service manual again, and it is nowhere to be found.
I guess I'll just start pulling...
Old 03-11-2009, 10:59 AM   #9
This should help (from the 09 service manual):
Using a screwdriver with its tip wrapped in protective tape, slide the handle plate of the back door trim board to disengage it.
Disengage the 3 claws and 9 clips and remove the back door trim board.
REMOVE BACK DOOR PANEL NO.2 PROTECTOR
(a) Disengage the claw and clip, then remove back door panel protector No. 2.
Remove any tape remaining on the back door side.
Old 03-11-2009, 12:33 PM   #10
Sodium Duck
╚══════════RN
12 fasteners? There must be something really awesome under there... LoL
Old 03-11-2009, 12:33 PM   #11
Sodium Duck
╚══════════RN
Thanks Scott!
Old 03-11-2009, 06:31 PM   #12
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
?? where did I miss the 09 service manual? is it online?
Old 03-11-2009, 07:39 PM   #13
Not yet. I joined the Toyota TIS to have online access to it.
Old 03-11-2009, 08:22 PM   #14
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
I could not find the instructions in the 2007 manual either. There's a picture of the removed rear interior panel in the Lighting manual.
Old 03-11-2009, 10:06 PM   #15
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Be Very careful insde the area off the back hatch ,where the recess is
for fingers to pull down hatch is a little plastic slot for a screw driver
insert screw driver and lever towards front of car this releases a plastic catch , now you are safe to remove cover by popping clips.
Old 06-14-2009, 04:12 PM   #16
Sodium Duck
╚══════════RN
Just in case anyone was curious, there's a bunch of junk behind this panel.
I was thinking about somehow fiberglassing in a sub, but there are too many things in the way. Plus, if you cut metal to make it fit, the door would lose it's structural integrity. Not worth it.
Old 09-04-2021, 09:01 AM   #17
Gragento
Newbie
Drives: Toyota Yaris High Pack 1.4 d4d
Plastic of the Trunk
Do you or anyone else have the same manual remove this panel for its alignment? There are 2 fixing Pins, just remove them and you're done?
Attached pictures or here:
https://drive.google.com/file/d/1liV...ew?usp=sharing
https://drive.google.com/file/d/1Q8K...ew?usp=sharing
Gragento is offline   Reply With Quote
rear doors hatchback speakers yv1650c In Car Entertainment + Electronics (audio / video / alarm) 1 05-01-2007 05:22 PM
Rear Center Toyota emblem removal spkrman Cosmetic Modifications (Exterior/Interior) 8 01-11-2007 12:37 PM
-- Liftback Rear Speaker Removal? -- rarmogan In Car Entertainment + Electronics (audio / video / alarm) 2 09-25-2006 03:48 PM
