Old 02-04-2018, 04:43 PM   #1
perro547
Drives: 1
Rear veiw camera install help
So I'm trying to install a rearview camera on a 2015 Yaris le. Those 2 bolts that hold the plastic cover in piece for the camera cutout won't come out. It just keeps spinning but does not get looser ?? I've been trying for a while and no progress. Also I'm trying to find which wire is the one I connect the reverse trigger to . I found these wired by my foot well not sure if it's even the right ones though.
Sent from my Moto G (4) using Tapatalk
perro547 is offline   Reply With Quote
Old 09-15-2021, 01:14 PM   #2
phpist
Drives: Yaris III
hello,
have you solved this? Was this connector for rear camera?
phpist is offline   Reply With Quote
Old 09-15-2021, 02:35 PM   #3
colinpilla
Drives: 2018 yaris
2018 Toyota yaris Thailand spec
Hi Guys i have 2018 Toyota yaris Thailand spec, i am having troubles installing my rear camera there isn't any RCA ports on the radio. what do i do.
colinpilla is offline   Reply With Quote
Old 09-15-2021, 07:29 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Originally Posted by phpist View Post
hello,
From memory, when I installed my rear view camera, that connector is for the central locking. Some versions of the hatchbacks in some countries have a key operated lock in the hatch. This connector then signals the doors to unlock or lock when the hatch key lock is operated.
I wasn't able to find any wiring in the hatch for a rear view camera, and ended up running a video cable all the way back to the radio. I tapped 12 volts from a reversing light to power the camera and provide a switching signal to the radio.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
Rear view camera William's Yaris Third Gen Yaris General Discussion 2 08-26-2017 11:48 AM
