Old 09-19-2021, 02:40 AM   #1
rayfloyd170
Drives: Yaris 2016 1.3 Manual
exhaust manifold heat shield (noise)
Last 6 months ago, I heard some minimal rattling sound due to the exhaust manifold heat shield specially during low rev and during acceleration.
I removed 3 bolts holding the heatshield and could not find any suspect other than some kind of circular metal washer "sponge" but it is fixed and could not be removed. i was thinking this could come a little loose and generating the noise.
i have managed to solve the issue by putting a small amount of white grease
on the metal "sponge" washer and this temporarily solves the problem for some time. Now, intermittently this noise is coming back and again i put some grease and this puts the noise away.
Other than completely removing the exhaust heatshield, what can you suggest to permanently eliminate this minimal rattling noise?
What kind of grease is best suited for this?
Thanks in adv.
rayfloyd170 is offline   Reply With Quote
Old 09-19-2021, 01:52 PM   #2
bronsin
bronsin's Avatar
Sounds to me like you have a pretty good handle On the problem.
Old 09-19-2021, 06:41 PM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
I put a slight bend in the heat shield near the bolt holes / washers that you mentioned. Just enough so that the washers hold the heat shield tight and stop it rattling.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 09-20-2021, 03:07 AM   #4
rayfloyd170
Thanks a lot for the tip
Will do it this weekend on my rest day.
Old 09-24-2021, 11:45 AM   #5
rayfloyd170
I finally took off the exhaust manifold heatshield today and was really surprised, all this time 1 out of 6 metal "sponge" washer was missing. This definitely caused the rattling noise due to imbalance as the metal washer functions as a cushion which sandwiches the heat shield.
I don't know if there is a particular part number for this or any store selling it, kindly let me know
Here goes the photo below.
Old 09-24-2021, 12:35 PM   #6
bronsin
bronsin's Avatar
Outstanding post! So many times you hear about rattles, but it’s hard to find what does it.
Now we did
Old 09-26-2021, 11:18 PM   #7
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Unfortunately the service manual doesn't list these as a separate item. It only shows the heat shield. The torque figure for the bolts at reinstallation is listed as 71 inch-lbs.
Old 09-27-2021, 02:54 AM   #8
rayfloyd170
Yes @kevinj93, you are right toyota does not sell it individually and they want you to spend for the whole assembly of the heatshield. Thankfully i managed to slice one thicker metallic anti-vibration washer into 2 equal parts. I managed to put it back since it is a bit flexible, perfectly sandwiches the heatshield without rattling.
Very happy now, no more noise during slow rev and acceleration. i will try to search in the scrap yard sometime whenever i am free.
I find this part online but only selling in bulk from India --> https://www.indiamart.com/proddetail...873693162.html
knitmesh --> https://knitmeshtechnologies.com/app...eld-isolators/
ebay --> https://www.ebay.com/itm/12311343536...oAAOSwa9Fa61GL
Mc Master Carr site --> https://www.mcmaster.com/vibration-c...threaded-hole/
hollandshielding site --> https://hollandshielding.com/Knitted...-washers-disks
ACS industries --> https://acsindustries.com/solutions/nvh/
Hope they are all flexible so you can easily take off from the sleeve.
2016 yaris noise monkeydave General Yaris / Vitz Discussion 1 10-20-2017 11:14 AM
Exhaust manifold damaged by corrosion donpalino DIY / Maintenance / Service 5 05-26-2015 05:38 PM
Exhaust manifold heat shield Problems. Help!! MaXx0909 DIY / Maintenance / Service 5 07-29-2013 11:30 PM
Exhaust heat shield.... vital? Beer Jammer DIY / Maintenance / Service 1 09-17-2010 10:52 AM
heat shield over manifold came loose, help?!? jeff69dini DIY / Maintenance / Service 8 09-14-2010 03:29 PM
