Old 11-16-2021, 03:12 AM   #1
racinkc1
Drives: 2008 1.5L BLUE YARIS
ATF and Filter Change.
Hello. I just bought this ATP filter kit and 4 quarts of Toyota ATF WS. Is there anything else I might need like a crush washer for the drain plug? Also wondering the filter and pan torque specs. I read somewhere on here 8FT/LB for the filter and 5.75FT/LB for the pan. Is that accurate? Doesnt seem tight enough....
racinkc1 is offline   Reply With Quote
Old 11-16-2021, 05:37 AM   #2
Signats
Signats's Avatar
Drives: 2008 hatch
Cut and paste from 2007 repair manual:
Install the oil pan with the 19 bolts.
Torque: 7.8 N*m (80 kgf*cm, 69 in.*lbf)
Install the valve body oil strainer assembly onto the
automatic transaxle with the 3 bolts.
Torque: 11 N*m (110 kgf*cm, 8 ft.*lbf)
Signats is offline   Reply With Quote
Old 11-16-2021, 05:41 PM   #3
racinkc1
Thanks for confirming
Old 11-27-2021, 02:28 PM   #4
IndestructibleYaris
I went without the crush washer and it hasn't leaked a drop. I never replace crush washers unless there's oil on the drain plug when I start the job
IndestructibleYaris is offline   Reply With Quote
Transmission flush, brake bleeding and oil change 06YarisRS DIY / Maintenance / Service 7 08-20-2020 07:15 AM
Snapped off an ATF pan bolt bairjo DIY / Maintenance / Service 13 03-14-2019 04:38 PM
Complete flush for ATF change? Lance16 DIY / Maintenance / Service 29 07-05-2017 10:26 PM
Replaced my ATF markitect DIY / Maintenance / Service 6 01-02-2014 11:10 PM
2007 Yaris 3 dr hatch ATF transmission capacities emgconsulting DIY / Maintenance / Service 1 07-22-2013 07:21 AM
