![]() Drives: 2006 1.3c Automatic Join Date: Feb 2022
Car drives fine on Friday. Today it wasn't turning on (video). Then it did
Hi all
I drove the car fine all Friday. Today (last night) I tried to turn it on and you can see what happened in the video (you might need to unmute) https://imgur.com/a/lALGK5B I went upstairs, came back, played with it a bit more, and then it eventually started. Any ideas? Year: 2006 Make/Model: Toyota Yaris Mileage: 92000 miles Engine size: 1296 cc Transmission Type: Automatic |
![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Battery....
Do a load test on the battery |
voltage is not CCA(cold cranking amps), you can easily have a 12-14v battery that has .5 of an amp in it which wont even run a headlight...12v on a battery does not mean the battery is good
you need to LOAD test the battery, heck if the car wont start, clean the terminals of the batter and tighten it back up, re-test, if it wont start.. the only "free" load test i know of to try is simple enough..flip your wipers up off the glass, turn the key on, and turn the heater on full blast, and listen to it, now turn on the wipers, did it slow?..now turn on the headlights, did it slow now?, hit the brakes and flip on the hazzards, if this makes the heater sound slowed down or "pulse" with the flashers then youve got a low amp weak battery in need of replacement |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
Definitely do some diagnostics on the electrical system
| enobmort42 - Photo-Scavenger Hunt! | enobmort42 | Photo-Video-Media Gallery | 9 | 03-05-2009 11:52 PM |
| CtrlAltDefeat - Photo-Scavenger Hunt | CtrlAltDefeat | Photo-Video-Media Gallery | 0 | 03-04-2009 03:14 AM |
| Black Friday | Bob_VT | Off-topic / Other Cars / Everything else Discussions | 70 | 11-29-2008 08:07 AM |
| New car shopping - long post | littlecarlove | General Yaris / Vitz Discussion | 19 | 11-01-2006 11:58 PM |
