![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
angle grind off lower alternator bolt?
The retard that replaced the alt overtightened the long through bolt
Someone recomended doing this as only/last resort...mine is seized on. I need to remove to replace water pump....its overheating...I doubt its the water pump though...but thats another issue. Last edited by Pinchlite; 05-06-2022 at 02:50 PM. |
is the head stripped or is it just spinning?, the issue i see with cutting it off is youll probably still be half stuck
| Grind, Grind, Grind | 2o6 | DIY / Maintenance / Service | 16 | 06-26-2013 08:24 PM |
| Lower control arm replacement 2005 Echo ? | Infinitrium | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-27-2012 04:23 PM |
| Should I lower the PSI during the Winter? | paulyd0021 | General Yaris / Vitz Discussion | 5 | 12-10-2009 07:49 PM |
| Lower Grill Replacement Idea (feeler) | counterfiend | Cosmetic Modifications (Exterior/Interior) | 7 | 09-24-2009 09:40 PM |
