![]() Drives: 2012 toyota yaris Join Date: Jun 2022
newby enquiry
Hi
Glad to find this forum. I just purchased a 2012 yaris YR NCP130R. It appears to be prewired for cruise control (blanked out control lights on dial), but I'm not 100% sure. There is a cruise control lever blank cover on the side where I guess the cc spindle goes through.. Is there a youtube link or whatever someone can provide to explain the fitting of one procedure. Thanks for your time |
take a look here in the forums theres a full write up with pic's
in a quick summery you need a CC stalk from 04-12 toyota....basicly anything and everything that had cc will have it, you also need the pigtail from the stalk to the snail, otherwise its a simple matter of pulling the steeringwheel pluging it in screwing it down and your done |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
I have the same model, and can confirm the cruise control works. Search the forum for third generation cruise control.
For the manual transmission, there is also a switch that needs to be installed on the clutch pedal. For an automatic, you only need to install the control stalk. The wiring is all in place. With automatic transmission, it's a 5 minute installation. The cruise control stalk is part number 84632-34011 The clutch switch is part number 88280-14030
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
Thanks guys for your help. I'll look through the forums and check the info out. Sounds promising tho. Just hope the Aussie models are wired up correctly.
I notice I do have the audio controls on my steering wheel. Does this complicate the matter too much.
GarisYaris |
nah its still the same setup, id be very suprised if it wasnt plug n play still
Then Again
Then again, if I disconnect the battery for airbag, I'm up for $150 bucks to get radio code from dealer as I don't know it ????
i didnt dissconnect mine, as for the radio code check the manual it might be in there, i thought you could just provide the dealer with the vind and get the radio code for free since you own the car
Yeah. I don't think I'll disconnect mine. My dealer wanted $80 bucks to delete radio code completely. Couldn't help anymore they said.
#11 | |
![]() Drives: 2008 Sedan Join Date: Sep 2017
#12 | |
wait if you have an 08 and it has the spots filled on the ECU than you dont need to run wires...your a plug n play..ie put in the CC unit and the jump cable at the snail, and verify the plug on the other side of the snail is in place the link will clear that up about some of the 08+ cars having "most" of the CC stuff pre-installed to the point of only needing to plug the CC unit in and a matching cable..no "non factory" additions |
#13 | |
So the wires I have are the blue and brown in the connector D3 under my steering column. What I do not have is a wire in the ECM pin 40 spot. I don’t know how to connect a wire from the ECM at this point, because I wasn’t expecting the wires that are in connector D3. I just don’t want to mess up my poor car, haha! Last edited by ShadowRabbit; 07-08-2022 at 04:41 AM. Reason: Phone typos |
let me see if i saved that pdf on one of my machines...
what i recall is that you need to run the signal wire from the CC unit to the ecm..but ill look for clarification...i know i was a lil worried about doing it too try this it helps clear up some things but its for the non factory CC install so its only partly usefull but all the "stock" wiring locations still apply https://www.yarisworld.com/forums/at...9&d=1251331564 |
If anyone in Australia has done the CC Mod on a 2012 Yaris NCP130, did you have to do the below mod...
"Those with the audio controls will need to transfer the two cruise control pins (in positions 1 and 2) from the 4 pin cruise control stalk wire to their 10 pin spiral cable connector (in positions 1 and 2)" or was it a simple plug and play procedure. Regards Garis |
It's a straight plug in.
Many Thanks
| Newby MPG Questions (Look out!) | Yaryaryaris | Fuel Economy Forum | 24 | 12-20-2009 10:09 AM |
| Newby questions re mods for towing | noraebong | Performance Modifications | 7 | 11-18-2009 12:14 AM |
| Wheel balancing Alumimum wheels: CAUTION NEWBY | tomjasz | Cosmetic Modifications (Exterior/Interior) | 3 | 08-20-2006 03:50 PM |
