Old 07-27-2022, 06:11 PM   #199
Originally Posted by kobe52 View Post
Bit late to the party but living in a rust prone area, will 44 ft lbs torque be enough with pretty weathered shock bolt and nut or should I loctite the shock nut on? Took quite a bit of work to get it off.
We are probably in the same rust belt. Looking at pics is tough but I think those threads are fine. Wire brush them a bit to get the gunk off, apply a little grease and spin the nut up and down the bolt a few times. Degrease the bolt and torque down the nut. 44 ft lbs is not really a great deal of torque and bolt will handle it just fine.
Old 07-28-2022, 06:25 AM   #200
kobe52
Drives: Yaris
Yep, GTA guy here. Was a little rough getting em off and on on the threads with rust but hasnt seemed to cross thread, atleast that time.
kobe52 is offline   Reply With Quote
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 02:05 PM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 03:26 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 02:46 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-06-2008 12:37 AM
DIY - TRD rear sway bar kurokoma-kun DIY / Maintenance / Service 0 10-20-2008 02:21 PM
