![]() Drives: 2008 Yaris Join Date: Sep 2021
Where to purchase rear exhaust/gas tank heat shield?
One section of the large reflective/metallic heat shield surrounding my exchange and protecting my gas tank on the rear of my 2008 yaris has completely corroded away.
I tried searching rockauto for exhaust heat shield and no luck. Google doesn't really seem to be much help either. It's the largest heat shield at the very back of the car just under the connection between the catalytic converter and the muffler if that helps? A part number would be great! Thanks all. |
Here are a few pictures of the heat shield that I just removed from the yaris: https://imgur.com/a/6fKQeCm
The one nut and partial bolt that I removed from the chassis are in the center of the heat shield there. The one bolt that was still securing the heat shield in place was so rusted that it snapped off inside the chassis as I was unscrewing it out damnit :S Bonus points for telling me how to get that portion of the bolt out of the chassis! |
wrecker/LKQ, dealer would likely be your only options
I can pretty much guarantee you that any car that's been loved for as long as ours have, in the environment we live in, is down a heat shield or two. Don't sweat it, run without.
If you're not comfortable running without the shield, here's a hack that works beautifully. Take a soup can and snip it into pieces that can be bent and shaped to act as the corroded mounting tabs. Pop rivet these to your heat shield, mark and drill holes to receive the underbody fasteners.
When it comes to the broken bolt, the only thing I can think of is using very good drill bits, try to core out a hole in the bolt. Hopefully a reversing bit would be able to get enough grip to back the remainder of it out.
You guys rock, thanks for the great advice :)
My heat shields corroded away completely quite some time ago.
When I visited the local shop and requested replacement, the mechanic was looking at me like I was completely nuts. He said that he has seen literally hundreds of cars without these and nobody was solving that. Many people actually lose them without even knowing it. And he actually made a good point that if the heatshield was sooo critical for safety, it would certainly not be made of thin corrodable material which is only hold in place by two tiny bolts. |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| Best place to purchase a Tanabe strut bar and or TRD Rear anti sway bar? | thomasward00 | General Yaris / Vitz Discussion | 3 | 07-12-2007 02:22 AM |
| General Warning and Fuel Tank Heat Shield | ttufrosty | General Yaris / Vitz Discussion | 8 | 05-31-2007 11:59 PM |
