Old 08-26-2022, 07:56 AM   #1
Doobiejack
Drives: 2018 Yaris Hatchback
Transmission fluid change for 2018 Yaris hatchback
I lost my maintenance schedule for my 2018 Yaris Hatchback. When should the first automatic transmission change take place? Is it 100,000 miles or sooner?
Doobiejack is offline   Reply With Quote
Old 08-26-2022, 03:07 PM   #2
bronsin
bronsin's Avatar
There isn’t a requirement to change it. And if you just drop the pan and clean or replace the filter you’re leaving about 6 to 8 quarts of old oil in the transmission. You’re only “changing“ two quarts.
If you want to “Change” it you can do it whenever you fancy.
Old 08-31-2022, 02:10 PM   #3
sh0rtlife
FWIW, automatic fluid only needs to be changed under 2 specific reasons, and this is true of ALL make model and brand
#1 the color has changed(darker with a smell)
#2 its been contaminated
in reality the only way to trash the fluid and make it need to be changed is 1. your pulling a trailer or hauling heavy, 2. you do a TON of hills.....either case you should have installed a cooler to prevent it..as its HEAT that kills a transmission, and said heat kills the fluid, but the damage of the heat is done to the trans FIRST and the fluid secondly...so if your fluids going dark..youve allready done trans damage
secondary FWIW, the ONLY way i know to fully change the fluid on an automatic..again regardless of make/model/brand/year if to open the output line to the radiator mounted cooler and connect a catch..keep in mind some high pressures at work here....and then put the transmission in neutral and start the engine, and let it idle till little to none comes out then promptly shut it down
1NZ-FE (TS) - transmission fluid change, 1.9 liters or let it overflow? johannes2k DIY / Maintenance / Service 5 08-30-2020 03:31 AM
2008 Yaris AT Fluid change Rutherfordman General Yaris / Vitz Discussion 8 07-13-2009 12:45 PM
WTT: my 07' Yaris Sedan A/T -> Yaris Hatchback FcukThis Cars for Sale by private party 0 01-20-2009 02:34 AM
