![]() Drives: 2007 Yaris Hatchback Join Date: May 2019
HELP! Washer Fluid Reservoir
I’m putting in a new windshield washer reservoir and can’t figure out a part. I’m not even sure what it is for. The reservoir only has 2 holes for the back and front windshield sensors. The only number I can find on the part is Y05 11068.
did you order the correct bottle?..im asking this as there are 2 different units 1 with 2 holes 1 with 3 holes
3holes=front and rear wipers and level sensor 2 holes= front only and level sensor |
I was wondering if that's what it might be, I of course threw out the old one and then came back months later to finally put the new one in. It still works without putting that piece in (must be the level sensor). Thank you!
| Inexpensive fix for low windshield washer fluid light stiuck on | Toolaholic | DIY / Maintenance / Service | 5 | 04-21-2020 03:46 PM |
| Manual Transmission Fluid Woes | tmontague | Performance Modifications | 4 | 10-08-2018 10:12 AM |
| Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 11:42 AM |
| Windshield Washer Fluid Reservoir level | romram | DIY / Maintenance / Service | 2 | 03-22-2015 05:16 PM |
| Washer Fluid & Other Questions | vaironl | DIY / Maintenance / Service | 1 | 11-16-2013 02:25 PM |
