Old 12-01-2022, 03:16 PM   #19
Neinris
Drives: 08 Yaris 3 Door Hatchback
That's interesting...
Found one in Amazon:
https://www.amazon.com/Variable-1533...87546138&psc=1
Neinris is offline   Reply With Quote
Old 12-02-2022, 12:15 PM   #20
Compeer
Drives: NCP90 TRD Yaris Manual
Notice tho it doesnt have the correct amount of holes or the stepped down parts that the real RS one has.
Compeer is offline   Reply With Quote
Old 12-02-2022, 08:06 PM   #21
Neinris
I counted 6 on one side and 3 on the other. What's the real RS's count?
Old 12-02-2022, 08:28 PM   #22
Compeer
6 holes as well plus holes in the tip. the holes tho are a bit larger and different towards the end, plus mine had that like 0.5mm step down, but the one the e85 all motor post guy used look like that aftermarket version you posted and they said it worked mint.
ALSO got to wonder what the clocking on the side is for!???? OEM RS doesnt have that, its just set where its at.
Old 10-15-2024, 11:19 PM   #23
Leospamplona
Drives: Yaris XP150
Can i only change to rs solenoid without changing the stock maf sensor? Will it damage the engine or have negative effects?thanks!
Leospamplona is offline   Reply With Quote
Old 11-18-2024, 12:58 PM   #24
Compeer
Doesnt effect anything other than supposed to have faster vvti reaction. So plug and play on any 1nz-fe
vvti solenoid
