Old 01-07-2023, 02:57 PM   #19
sh0rtlife
to hell with the sensor how do they fit, look and hows your "position" in relation to the OE seats?
Old 01-12-2023, 10:55 AM   #20
theinteriorautomechanic
Drives: Slowcart
Post some pictures of the seats installed please
theinteriorautomechanic is offline   Reply With Quote
Old 01-13-2023, 12:57 PM   #21
Compeer
Drives: NCP90 TRD Yaris Manual
You want the seats from a zz231 celica. Ive read they bolt in but I am waiting to buy some to confirm.
Late 2006 on celica seats will have the same airbag and seat sensors letting us keep the factory air bag seat up is the main reason I want to try.
They are both small cars so dimensions wise they will be mint its just if the rails work or can be swapped.
Compeer is offline   Reply With Quote
Old 01-20-2023, 01:59 AM   #22
Kasbien
Kasbien's Avatar
Drives: 07 Sedan (AT)
I don't actually have the FRS seats installed yet. I went as far as buying them and working on the seat brackets before even having looked underneath them. Zero cognitive processing in that moment. Live and learn. Airbags are important to me, so if I can't get them to work then I'll cut my losses before hacking up the seat rails.
Kasbien is offline   Reply With Quote
Old 01-20-2023, 02:01 AM   #23
Kasbien
Kasbien's Avatar
I hadn't thought of that car. Good idea! I'll check my local wreckers.
Edit: Seems like others have tried. Not a direct swap. https://www.yarisworld.com/forums/sh...ad.php?t=52507
Old 01-20-2023, 08:01 PM   #24
sh0rtlife
has anyone done TC seats..they sure loook like a hell of an improvement..was eyeballing a set in the wrecker today...god i HATE smokers..they ALWAYS burn the damn seats
Old 01-31-2023, 04:54 PM   #25
librathedepartedcat
Drives: Toyota
I haven't personally tried any of the newer Yaris seats, but a few people have, and they seem to think they are an improvement. The 2012+ seats are a bit wider and more comfortable, but they don't fit in an 06-11 Yaris without modification. As for custom seat rails and racing seats, it can be done but it takes a lot of time and money. You'll have to find the right parts and fabricate them, and then you'll need to get the seats installed and wired. It's a big project, but if you're willing to put in the work, it can make a big difference in the comfort and look of your Yaris.
librathedepartedcat is offline   Reply With Quote
Old 02-05-2023, 11:27 AM   #26
sh0rtlife
as a fabricator, general mechanic and retired autobody....i can say that seat tracks are the "easy part" but the seat shape is the real issue, which is why i ask..pan and spring depth is the one the will almost always be the primary issue, followed by back rest stop points and total rise....those 2 things are a "make or break" for fitting in ANY car...most of which cant be verifyed without having both the seats and the body and tossing them in place to figure it out
rail width is fairly easy to overcome "if" theres nothing low hanging under the seat
Old 02-07-2023, 04:07 PM   #27
Kasbien
Kasbien's Avatar
Small update...
I noticed that 09-12 Yaris Sedans out of the United States can come have nicer looking seats than previous sedan and hatchback years. See attached photo. Can anyone attest to them having improved comfort? The big hurdle for obtaining them would be finding some in half-decent condition and without an enormous shipping bill up to Washington where I can at least cross the border and grab them without having to drive down to California.
A more realistic solution is to work with what I've got. The seat brackets are ready to go (I highly recommend just dropping the coin on the Planted ones) and I found a work around on the Tacoma forums that at least solves the PASSENGER wiring issues since it involves retaining the seat sensors/harness out of your stock seats. The DRIVER seat positioning sensor is not address in the thread, so I'll have to come up with something. Without a datum for reference measurements, I don't know how the heck I would accurately retrofit the position sensor on the FSR seat... I guess I'll cross that bridge when I come to it.
Old 02-09-2023, 01:12 AM   #28
sh0rtlife
those sure look alot like XB seats but less than TC seats....honestly after seeing all the NICE TC seats in the pick n pulls up in washington im very..VERY tempted to snag a set and try em out
Old 02-13-2023, 03:57 PM   #29
Kasbien
Kasbien's Avatar
Let us know if you do!
Front seat modification. Increase thigh support. PetersRedYaris DIY / Maintenance / Service 36 08-22-2018 01:37 PM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
Complete Racing Seat Install Guide advocate DIY / Maintenance / Service 7 11-25-2009 02:26 AM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
Seat Covers...? Jem_hadar Cosmetic Modifications (Exterior/Interior) 9 09-22-2007 02:57 AM
