Old 03-14-2023, 01:03 AM   #1
MyBlueYar
Drives: 2009 Toyota Yaris
Lightweight pulleys: reliability & smoothness
Hello all you Yaris enthusiasts. I'm a recently new Yaris owner, having bought an '09 Yaris hatchback. I've enjoyed the car thoroughly up until now, but am just now dipping my toes into the waters of the vast depth of knowledge this site offers.
My first upgrade was ditching the stock steelies in favor of a set of lightweight wheels from a Mini Cooper. I was lucky enough to find a set with new tires already on them, and the guy gave me a very good deal in the process. The wheels were the 5 star spooler wheels (R100 I believe), and if the online published numbers are to be believed, they are 13.7 lbs each, an improvement over the original steelies. The vast improvement in the interior sound levels just from the tire change was very noticeable.
I've scoured this site about NST lightweight pulleys (and to an extent MI as well) in my search for my next mod. Mind you, I'm probably one of the few people who is mostly content with the stock hp of our mighty Yaris. While I think another 5-10 hp would be ideal, I did not go into this purchase with high expectations in that regard.
On NST's website, they address one of the most common concerns about engine balancing (internal vs external) and dispel the myth of lightweight pulleys destroying the modern day engine that is internally balanced.
My question to those of you who have already modded your Yaris with one or more of their lightweight pulleys is this: I'm not after crazy hp gains with a simple pulley upgrade, that much I am realistic about. My bigger goal with this car and the incremental improvements is to make it somewhat quieter, and if possible, smoother in its daily operation.
So for those of you with NST pulleys installed, how did it affect the engine smoothness in terms of day to day driving? And secondly, I believe I read a post about someone who installed the crank pulley on their car, and found it made it a bit more jerky in taking off. What was your experience?
Any feedback on these lightweight pulleys from those of you who have a before & after would be greatly appreciated. Thanks in advance -
MyBlueYar is offline   Reply With Quote
Old 03-14-2023, 07:26 AM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
I have the NST crank pulley on my 2014 and it makes the engine more responsive yes, but you lose rotating inertia which can make it annoying to drive in traffic if you have a manual.
Especially so with the annoyingly touchy but somehow not touchy E-throttle mapping the Yaris has. I'm actually considering going back to the stock pulley to regain some of that inertia back and make it easier to be smooth when taking off but I threw out my stock pulley like an idiot so now I have to go pillage one from the junkyard
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 03-14-2023, 11:44 PM   #3
remcafee
remember that it has nothing to do with balancing, it has to do with harmonics, it does not have any harmonic dapening compared to the stock pulley which has rubber molded into it to dampen harmonics created from inertia, harmonic dampening is important to reduce wear on crankshaft main bearings, as without harmonic dapening the harmonics dont get cancelled out and transfer all through the crankshaft
Old 03-15-2023, 12:04 AM   #4
MyBlueYar
REM - I do realize what you say about harmonic dampening, and have read several posts on here that essentially agree with you. My loose paraphrase of NST's website that takes the opposite position was simply that, positing that according to them, engine balancing is apparently not a problem in terms of long term engine/bearing reliability.
I don't have an official position myself yet, as there are two sides that take completely opposite views, some even coming from the camp of automotive engineers.
But I wanted to do my due diligence before jumping at the first chance of putting an underweight pulley(s) on my newly purchased Yaris. For that, thank you very much for your input and giving me additional food for thought.
Old 03-15-2023, 06:21 AM   #5
sh0rtlife
your half right
the harmonic aspect of it can and will remove excess noise and "jitter" from the crank...the same has been done on some engines with a counter shaft..which is escentialy a second crankshaft spining nothing but weights
think of it more as a spinning chunk of dyno mat for the "feel" of the engine
Old 03-16-2023, 02:58 PM   #6
remcafee
most likely your engine will be fine with the nst pulley, there is no doubt that it puts more wear on the crankshaft though
Old 03-16-2023, 05:29 PM   #7
MyBlueYar
https://www.nonstoptuning.co/blog/li...od-bad-depends
Food for thought pertaining to lightweight pulleys.
Old 03-17-2023, 10:30 AM   #8
Neinris
Drives: 08 Yaris 3 Door Hatchback
Maybe go with something that's not super light, something that just bring it half the weight maybe?
https://www.heeltoeauto.com/alutec-p...etc-cp-18.html
https://www.youtube.com/watch?v=Vo2g7544Fz8
Neinris is offline   Reply With Quote
Old 03-17-2023, 08:28 PM   #9
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
I didn't realize someone other than NST still made lightweight pullies for the 1NZ. Neat
2014 NCP131 5 Speed
Old 03-18-2023, 01:28 AM   #10
Compeer
Drives: NCP90 TRD Yaris Manual
Theres one on Ebay and then theres also Works enginnering got them linked in the discord.
Compeer is offline   Reply With Quote
Old 03-18-2023, 02:06 PM   #11
Neinris
Way to promote the discord channel...
Old 03-19-2023, 02:40 PM   #12
sh0rtlife
i use my 58 ford as a solid reference on "harmonic balancer removal"..its an internally balance 312 police interceptor V8..one day it simply let the harmonic balance section go off the engine at idle so no harm no foul...i drove it like that for a while and yes the performance gains from losing the weight was pretty big, but the "harmonic vibration" from not having it was weird and could be compared to the way an exhaust drone works...it was most noticeable at idle as a "wave" of a harmonic vibration would just ripple thru the car...it was gone off idle but if you held a steady rpm for more than 5 mins youd find it again
dont get me wrong v8 5.1 vs I4 1.5, but the principle remains the same...also mind you its not very bad and the way the yaris engine mounts work they may soak up some of it as well....
Lightweight crank pulleys? ltwargssf Performance Modifications 8 02-25-2023 07:43 PM
Pulleys interchangeable? Swing Performance Modifications 16 05-07-2014 01:16 PM
Concerns about pulley's Black_griffin6 Performance Modifications 35 02-04-2012 12:05 PM
Pulleys, pulleys, pulleys! Deltasix Performance Modifications 15 03-21-2009 11:10 PM
NST lightweight pulleys kit t0m4s Central and South America 23 02-17-2009 04:10 AM
