![]() Drives: 07 Yaris Join Date: Apr 2022
Horn replacement
I have an 07 Yaris and the horn isn't that loud. I'd like to replace it with one that's louder. What replacement horn I should use?
youll find most any toyota horn will fit and bolt up, tho youll likely need to change the pigtail so get the pigtail with the horn..id recomend one from a pickup or 4 runner if you want to stay toyota..otherwise aftermarket you can run anything you want even air horns
![]() ![]() Drives: . Join Date: Mar 2019
Amazon has an assortment of horns from practical to absurd, and many have videos showing what the sound is like with decibel meters.
I have one that sounds like a 1980's large car. (I chose to skip the train horn) ((would have probably slowed the car by 5 mph while in use anyway)) |
What I did in my '09 Yaris was to jut get a "Y" connector .
Then connect two horns (high and low sounds) that for that expensive two horn expensive car sound The one stock horn is quite pathetic sounding. Last edited by RedRide; 02-20-2024 at 03:05 PM. |
| DIY aftermarket steering wheel install with horn and airbag delete | tmontague | Performance Modifications | 19 | 11-30-2018 12:19 PM |
| Broken Horn FIXED! | zerosl | DIY / Maintenance / Service | 0 | 10-10-2017 03:14 PM |
| Horn Button Replacement | BobTheYaris | DIY / Maintenance / Service | 4 | 11-04-2014 01:22 PM |
| Yaris Horn install 15 Mins, WOLO 380 2T, Stock is too weak. | WRX | Third Gen Yaris General Discussion | 2 | 04-19-2014 10:07 PM |
| DIY Horn Replacement. | screenprintr | DIY / Maintenance / Service | 9 | 12-29-2012 01:29 AM |
