![]() Drives: Yaris I Join Date: May 2018
Trunk inside light removal.
Hiiy Folks,
A happy Yaris owner here. I have a TOYOTA Yaris II Hatchback (XP9) (01.2005-12.2014). Recently two times in a year I had this situation. Normally I close trunk door with average force And sometimes it doesn't close completely and A small light was ON all the time. Two times my battery was drained due to that And I then my friend need to come to aid. My question is I really don't use that light and I Don't want to worry about this battery drain matter in future. Can I just remove the bulb from holder and be tention free. Or should I do anything after removing the bulb. Or any suggestions. Thanks in advance. |
Just remove the bulb.
if your looking for a blanking plate, the hatchbacks have a blank plate on the center of the hatch that just so happens to be the EXACT size of the light unit...in other words you can use that plate to blank your light or you can do some work and put a light where the blank plate is.....seems to be a common part across the scion line too
#4 | |
![]() ![]() Drives: . Join Date: Mar 2019
nope but you could pull yours and get a part number
| Tags |
| trunk, trunk light, trunk release |
| Alternator Diagnosis, Removal, Rebuild, and Installation Guide | IndestructibleYaris | DIY / Maintenance / Service | 2 | 02-25-2022 03:07 PM |
| Battery Light Flickering over 3k rpm | 07GOKRT | General Yaris / Vitz Discussion | 6 | 11-25-2017 08:49 PM |
| Toyota yaris 2008 trunk indicator | Joshmz | DIY / Maintenance / Service | 1 | 11-16-2017 07:16 PM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
| Intermittent low oil pressure light. | Inspector14 | DIY / Maintenance / Service | 23 | 03-29-2010 01:46 PM |
