Old 10-05-2023, 11:17 PM   #19
satannuts
Drives: Toyota Yars
Originally Posted by seatech30 View Post
Edit2: Went with 50ft-lbf. Tried to go for 74ft-lbf, but felt like too much, didn't get there.
I did a trial on removing the ENGINE MOVING CONTROL ROD BRACKET and it seems the bottom of the top two bolts is going to give me a hard time. I'm guessing I can jack the transmission up? Will loosening be necessary on the other mounts or is there anything else I should watch for?
Hey, did you ever get that hard to reach bolt out?
I just tried to change this lower engine moving control rod and bracket, but I couldn't get to that one hard to reach bolt.
satannuts is offline   Reply With Quote
Torque Specs 2009 Suspension GrayYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 04-23-2014 12:04 AM
looking for torque specs on front caliper bolts 07 yaris mikee07 DIY / Maintenance / Service 2 10-21-2012 04:36 PM
torque for wheel bolts? caineroad Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-13-2012 09:07 PM
Suspension Torque Specs pls nisyota Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 12-21-2010 08:04 AM
Tighten bolts to factory specs? marlondog Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 10-19-2010 06:18 PM
