Old 10-07-2023, 11:48 PM   #1
An1992
Drives: Toyota Yaris 2007 1krfe
Lightbulb Electronic filter to deleteri p0420
I have a European Toyota yaris 2 from 2007, with a 1.0 1krfe engine with p0420 error.. I purchased an extension to remove the oxygen probe downstream of the catalytic converter, but the error appears again... Currently the probe values ​​are between 0.1 and 0.85volts... I think that sometimes it exceeds this and the error appears.. I would like to modify the electrical wiring of the probe with the electrical filter, so as to always have volts values ​​in the suitable range but I found various information on the net. Do you have the wiring diagram compatible with Toyota Yaris? Thank you
An1992 is offline   Reply With Quote
Old 10-08-2023, 01:52 AM   #2
An1992
I apologize if I post another site, thanking you but I found this one which can be useful, however they are two different circuits
Old 10-09-2023, 05:48 PM   #3
sh0rtlife
get a longer tube version with a "mini cat" in the tube..should solve the issue...if it doesn youve got engine issues
Old 10-23-2023, 03:30 AM   #4
An1992
What kind of engine problem if any? Piece with 90* or direct filter?
Old 08-02-2024, 06:30 AM   #5
An1992
"I use one straight + one 90 with mini cat, OBD error present but now no warning light on the dashboard, probably doesn't solve it but delays the notification a lot. I also tried with an electronic filter on the lambda sensor wiring but nothing."
VVT Oil Control Valve Filter Replacement (the other oil filter) 2bz DIY / Maintenance / Service 7 08-02-2024 02:44 AM
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Car shuts off when A/C turned on... Howster DIY / Maintenance / Service 33 07-06-2013 05:00 PM
Beware WIX Filter #51394 zkay DIY / Maintenance / Service 19 12-22-2012 12:09 AM
DIY - Cabin air filter location (Belta, Vios, Yaris sedan) Murtaza_murti DIY / Maintenance / Service 5 04-05-2012 11:03 AM
