Old 12-04-2023, 02:54 PM   #19
Ivory
Yaris Lover
Drives: 2008 White LB, AT
PICTURES and WIRE NUMBERS
Pictures and wire Numbers gathered from other posts, so its all here in one place.
I hope i did this right? If not sorry, moderators can fix it if need be.
All credit goes to CTScott and Tmontague.
Ivory is offline   Reply With Quote
Old 12-04-2023, 03:26 PM   #20
Ivory
Yaris Lover
Change jumper on Brain for NEGATIVE Pulse for parking lights
Old 12-04-2023, 03:46 PM   #21
Ivory
Yaris Lover
Avital 2101L for direct swap of Valet 712T
Bought the Avital 2101L kit from Amazon to replace an IDENTICAL Valet 712T that I had installed when I purchased new in 2008 (15 yrs!). It seemed like it was getting weak when unlocking They never hooked up the parking light portion so I scoured these forums to hook that up.
The Avital look like it replaces several of the old models 412v, 211hv...etc
Old 07-04-2025, 09:03 AM   #22
Walsh11
Drives: 2013 Yaris
Does anyone know if 2013 is the same as these older models? having horrible difficulties finding the open and close wires. WIll try these brown and green today. This is a must to add this keyless entry.
Walsh11 is offline   Reply With Quote
Old 07-04-2025, 11:11 AM   #23
Walsh11
Drives: 2013 Yaris
The 2013 yaris... The white module on the drivers side kick panel at the bottom (one small brown, small white with black stripe wire, and large white wire with black stripe) seems to be for the electric locks. when this module is taken out, the door locks stop. but why does every wiring diagram I look at have different colors for this? on here I read green and brown, etc.
Old 07-06-2025, 08:12 AM   #24
Walsh11
Drives: 2013 Yaris
FINALLY!!! On the 2013 Yaris, the Tan (unlock) and the purple (lock) are the 2 wires. Behind the radio I found that the blue wire was constant 12.5 volts. If I knew all this the first day, the project would have been done in 1 hour. Anyway it works!!!!! Friggin A.
Old 07-06-2025, 08:13 AM   #25
Walsh11
Drives: 2013 Yaris
NEXT PROJECT. Does anyone know how to disable the tire light on the dash besides replacing tire sensors?
2014 Keyless Entry Install Question GMRelkin DIY / Maintenance / Service 4 03-09-2017 11:26 PM
keyless entry issues azamora General Yaris / Vitz Discussion 0 10-29-2013 08:29 PM
Keyless Entry Remotes are dead... now what? Zanutto General Yaris / Vitz Discussion 7 01-11-2012 05:17 AM
Keyless Entry BLKYRSSDN In Car Entertainment + Electronics (audio / video / alarm) 44 09-16-2007 10:27 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
