Old 03-16-2024, 12:14 AM   #163
CrimsonEclipse
Drives: .
Finally finally FINALLY getting to the CC mod
Looking at the install guide, it seems to imply that my 2011 M/T doesn't need wiring installed. Looks like it already has a clutch switch installed, and it seems that all I need to do is install the stalk.
Does that sound right?
(would be great if I can do this for $35)
CrimsonEclipse is offline   Reply With Quote
Old 03-16-2024, 10:00 AM   #164
Gemak
Drives: 2014 Yaris,TRD sway bar, suspe
I have AT and followed the guides in this thread and now I have CC. Go for it, just be careful with the air bag
Gemak is offline   Reply With Quote
Old 07-30-2024, 12:53 AM   #165
CarpeDiem
Drives: 2008 Yaris Sedan
Hey guys, I got the kit today and installed the CC in a 2008 Yaris (no cruise light)...fast forward and I can't seem to get it to work. Did some troubleshooting over all connections (Pins are fully seated), checked the ground and the connection at the ECM all seem fine. When checking the voltage at D3 pin1 I have 13.3V, hold down the on/off switch and still 13.3V (not going to 0V). Could it be possible that the offshore Amazon stalk is bad out of the box? Any thoughts?
Thanks in advance
CarpeDiem is offline   Reply With Quote
Old 08-10-2024, 10:47 PM   #166
Markwelch415
Drives: 08 hatchback
Does anyone have a link for the instructions? I can't seem to get this one to work. Thanks! In very interested in doing this!
Markwelch415 is offline   Reply With Quote
Old 08-11-2024, 07:58 PM   #167
thetut
Drives: 2007 4dr sedan
Read post #152
thetut is offline   Reply With Quote
Old 08-12-2024, 07:16 AM   #168
BLH
Drives: 2007 Yaris Sedan
It is in post #162
BLH is offline   Reply With Quote
Old 10-13-2024, 07:17 PM   #169
Cris_co1221
Drives: 2007 Yaris 3dr
Thanks in advance
I am having the same issue, but a 2007 3dr manual. I have all oem parts but cc not working, and same voltage issue when depressing the on/off switch.
Cris_co1221 is offline   Reply With Quote
Old 10-19-2024, 07:41 PM   #170
Cris_co1221
My issue was pin #2 on d3 wasn’t fully inserted (ground wire), got that hooked up and am fine now.
Old 06-01-2025, 11:19 PM   #171
scott10301
Drives: 2007 3dr Hatchback
Just did the install today and no luck. I have a 2007 with no indicator light and want to troubleshoot to see if I'm at least the switch to the ECM is working.
How do I troubleshoot this? I saw that some are mentioning that they're testing voltage while depressing the on/off switch. Are you removing the pin from the D3 connector and then using a multimeter to test? I'm not sure how else that would be done. I did pull the pin and checked and am getting 13.3 volts whether I press the on/off button or not.
scott10301 is offline   Reply With Quote
Old 08-11-2025, 06:20 PM   #172
scott10301
Update - I found the issue. The splice connector under the hood was not set up properly. Set it up correctly and all is working well.
Old 10-27-2025, 03:04 PM   #173
Bastnt
Drives: Toyota Yaris 3 100 VVT-i 2015
GIVING ADVICE TO AVOID A STUPID MISTAKE I MADE on my Toyota Yaris III (100 VVT-i Collection 5p, 2010–2015)
I spent a lot of time browsing forums to get the cruise control stalk to work on my car (the clutch switch and CC light on the instrument cluster were already in place).
The reason it wasn’t working was that I had wired it incorrectly in the steering wheel. At first, I plugged the stalk into the brown cable connector—it fit, but it was a bit smaller. Instead, I should have connected it where all the steering wheel cables meet (blue, brown, and yellow connectors). There was an empty slot there that perfectly matched the stalk connector.
For other Yaris models, you might need to install additional parts. Here’s a great step-by-step DIY guide:
https://www.toyotanation.com/attachm...iy-pdf.419080/
Bastnt is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 01:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
