Old 03-31-2024, 09:52 AM   #1
YarisLurker
Drives: Yaris
manual transmission axle seal replacement
Want to save those who decide to do this job some frustration. I recently decided to replace my axles on both sides trying to chase down a pop sound that had started happening. Its a long story but here's what is relevant to this post. When you replace the axle seal you do NOT drive it in as far as it goes (like every other seal you have replaced) because there is a max depth that the seal is supposed to go in, approx 10mm max.
I share this tidbit because the only way I found this out was from randomly watching YouTube videos and finding some posts that talked about what I had experienced, I had replaced the seals on the drivers side twice and it was still leaking. I went to the dealer and bought the $25 OEM seal thinking the aftermarket seals might be the problem. So on the third time I used a dial caliper to measure the depth as I drove the seal in and used the 10mm max as the limit and voila the seal is actually sealing!
YarisLurker is offline   Reply With Quote
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 12:56 PM
Is there a difference in cv axles for auto and manual transmission? Yaris709 DIY / Maintenance / Service 4 08-06-2017 09:30 AM
Car will shift into gears (manual transmission) but won't move kustomrtr DIY / Maintenance / Service 4 04-11-2017 01:44 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 05:25 PM
