Old 02-01-2025, 02:19 PM   #1
rexkh
Drives: 2008 Toyota Yaris
Clutch or Transmission Problem
I was a nightmare last night to move a car from a complete stop with 3rd gear. It doesn't matter if I shift to 1st or 5th gear, it will snap in 3rd gear. Same for 2nd and Reverse, it will get in 4th gear. Is it clutch or Transmission Problem?
Please watch a video for details
YouTube
rexkh is offline   Reply With Quote
Old 02-06-2025, 12:11 AM   #2
Gdawgs
Drives: 2010 Yaris
That wouldn't have anything to do with the clutch.
Just a guess here, but there a plastic body that the shift lever attaches to underneath the rubber boot that the lever goes through. You can pull that boot up easily(just grab it at the bottom where it attached to the plastic cover and ease it up along the edges) then you can see in there. Once you look in there, I think you'll find a broken piece of plastic on the left side.
Gdawgs is offline   Reply With Quote
Old 02-13-2025, 05:32 PM   #3
bronsin
bronsin's Avatar
Sounds to me like your shift mechanism which I believe is by cable is not aligned correctly.
Wierd problem RPM's revving when shifting chrisgblues DIY / Maintenance / Service 12 06-29-2017 06:33 PM
Car will shift into gears (manual transmission) but won't move kustomrtr DIY / Maintenance / Service 4 04-11-2017 01:44 PM
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 04:59 AM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 04:48 PM
'54 T2 Yaris 1.0 VVTi automatic clutch / gearbox / starting problem Lettuce UK 0 09-30-2010 07:21 AM
