Old 03-15-2025, 09:45 AM   #1
vettehigh
Drives: 2009 Yaris Hatchback
Question Exhaust pipe crack and expense
My girls 2009 Yaris Hatchback 5-speed 1.5L has a 1/4 inch exhaust leak coming from the passenger rear where the hanger is. If that can not be welded, you need to get the complete exhaust from engine back for around $1200 from the dealer which is nuts.
Any input would be great
vettehigh is offline   Reply With Quote
Old 03-15-2025, 10:10 AM   #2
Replacement pipes from the resonator back to muffler flange are available. Replacing that piece plus labour should be less than $200.
Old 03-15-2025, 10:18 AM   #3
I currently am using this piece. American pricing is a hell of a lot less.
Old 03-15-2025, 10:23 AM   #4
vettehigh
https://parts.conicellitoyotaofconsh...ipe-1741021541
How is that possible with the cat
Old 03-15-2025, 10:30 AM   #5
Pipe is cut where I've drawn the line. New piece replaces the length to the right of line. Resonator is immediately to the left.
Old 03-15-2025, 10:35 AM   #6
vettehigh
And that is a direct connect to the rear muffler? Also, I'm in NY and that replacement pipe is from Canada, can't find it here in the states
Old 03-15-2025, 10:37 AM   #7
Yes, it's direct connect to muffler. I know it's Canadian, but American sources can be found.
Old 03-15-2025, 10:45 AM   #8
vettehigh
https://www.ebay.com/itm/19636576277...3ABFBM8OnnoLNl
Is this the same? This states Part#: R51362-AI
Old 03-15-2025, 11:06 AM   #9
Yes it is. I've was searching and spotted for cheaper on eBay store for upswautoparts in New Jersey.
Old 03-15-2025, 11:11 AM   #10
vettehigh
May you send me the link. I put the part # in, but did not come up via upswautoparts
Many thanks also for helping me
Old 03-15-2025, 11:13 AM   #11
vettehigh
https://www.ebay.com/itm/18694849190...4AAOSwXNZnrfET
This?
Old 03-15-2025, 11:23 AM   #12
That would be good if you need a resonator as well. My first leak was holes developing at the resonator hanger. Might want to take look there. If it's solid, then you just need this
https://www.ebay.ca/itm/176202383918...mis&media=COPY
Old 03-15-2025, 11:30 AM   #13
vettehigh
Thank you again. Just wonder if the quality of the metal they sell is bad, due to their prices being so low
Old 03-15-2025, 11:38 AM   #14
Metal on aftermarket is not as good as OEM, but good for several more years of running. Just have the union between old and new clamped, not welded. Cheap enough that if it fails, replace again. Also, a welded joint on old pipe almost certainly guarantees that your next point of failure will be that weld.
Old 03-15-2025, 11:46 AM   #15
vettehigh
Thumbs up
I'm taking her Yaris in on Friday and will post back to you that afternoon. Hopefully the tiny crack can be welded, if not, then I will get that pipe
Old 03-17-2025, 12:52 PM   #16
bairjo
Just a word to the wise... When you replace the muffler, and you will soon, get an OEM muffler. I made the mistake of saving a buck with an aftermarket muffler . Between the edge of it unavoidably rubbing and bouncing against the underside of the car making an annoying noise coupled with that it sounded like hollow tin can, i tore it off and threw it in the steel scrap dumpster at work after one week. But hey, you might like that...I didn't.
Old 03-17-2025, 04:52 PM   #17
vettehigh
I'm OE 99% of the time. Yes, I would get OE muffler along with OE nuts/bolts/gaskets too
Old 03-17-2025, 04:54 PM   #18
vettehigh
If there are other cracks in the system, I would think about this Magnaflow system for her along with new OE muffler. I can get it for around $700 shipped. Only issue I see, will this still pass NYS computer inspection without being CARB compliant?
https://www.magnaflow.com/products/5...E3VC3N_ug6LZPL
