Old 04-11-2025, 07:50 PM   #1
croustian68
Drives: Yaris LE 5dr 2016 AT Blue
Lightbulb 2016 Le 4d hatch
i everyone,
I’m upgrading the audio in my **2016 Toyota Yaris (4-door, automatic, Canadian model)** and need advice on two things:
### **1. Replacing Door Speakers (No Cutting, OEM Connectors)**
I want to replace the factory speakers **without cutting any wires** or damaging clips/panels. Here’s what I need:
- **Speaker adapters**: Which **harness adapters** (e.g., Metra 72-8104?) and **mounting brackets** fit the 2016 Yaris doors?
- **Step-by-step tips**: How to safely remove door panels (especially the front doors)? Any hidden clips/screws I should know about?
- **Polarity**: How to confirm +/- wires without a multimeter?
### **2. Running Amp Power Wire (Battery to Trunk)**
I’m installing an amp in the trunk and need to route **4-gauge power wire** from the battery. Questions:
- **Firewall passthrough**: Where’s the best grommet to use behind the glovebox? (Photos would help!)
- **Routing path**: Along the sill panels or under the carpet? Any tricky spots to avoid?
- **Grounding**: Best grounding point near the trunk?
**Additional Info:**
- I’m in Canada (cold winters – any wire insulation tips?).
- I’d prefer **OEM-friendly solutions** (no cutting/drilling if possible).
Thanks in advance! Photos, links to adapters, or personal experience with this gen Yaris would be *hugely* appreciated.
croustian68 is offline   Reply With Quote
Old 04-14-2025, 06:05 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
Metra 72-8104 should be the correct adapter harness for your car.
If I remember right, the speakers in our 3rd gens are riveted on and will need to be drilled out.
I live in Alberta, -40s are the norm during winter, whatever insulation comes from the factory should be sufficient for Montreal.
https://paulstravelpictures.com/Toyo...Removal-Guide/
This dude has a bunch of really good guides on maintenance stuff regarding 3rd gens, give his site a look.
I can't help you about amp power, audio mods aren't my thing outside of a good set of speakers. lol
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
xp130 yaris 2016 woofer
2016 hatch 5dr firewall croustian68 In Car Entertainment + Electronics (audio / video / alarm) 0 06-15-2021 02:05 PM
2016 hatch dna motor fog light install question Philthy DIY / Maintenance / Service 0 11-03-2018 10:48 PM
Yaris Hatch Leak Finally Fixed Yari$ DIY / Maintenance / Service 2 07-09-2017 10:43 PM
DIY: Hatch Popper using Scion IQ Hatch Handle (2006-2011 Liftback) CTScott DIY / Maintenance / Service 15 12-30-2015 07:27 PM
2016 Hatch 428CobraJet Third Gen Yaris General Discussion 26 09-10-2015 06:53 PM
