Old 04-13-2025, 12:53 PM   #1
romram
Drives: yaris hatchback
Synthetic Oil back to Conventional
Got my 2010 yaris service at toyota dealer to have serviced and replaced front brakes ( rotor/pads/shims). eventually had my change oil plus filter and multipoint inspection for 185k Miles
i been using conventional oil since day one (toyota oil @ $ 13.25 ).
for some reason, a NEW asst. service manager wrote in the service card to use SYNTHETIC OIL 0W20. I found it out when i was paying my bills. The price is not the issue thou it cost more @ $44.75.
my concern is, if i can still go back to conventional oil at 190k, since i heard you can't go back to conventional oil once you used synthetic oil, now it will be serviced every 10k and not 5k. In the oil cap recommend SAE 5W-30 ( will it affect any)
any advice? thanks
romram is offline   Reply With Quote
Old 04-16-2025, 11:25 AM   #2
crashboombang
crashboombang's Avatar
Drives: Toyota Yaris
The issue of switching from synthetic oil to conventional oil generates a lot of debate. However, it’s important to note that switching back to conventional oil can be done without major problems, even if synthetic oil was used previously. The myth that this isn’t possible likely stems from the fact that synthetic oil has better cleaning and anti-friction properties, which might slightly alter engine performance. If you’re switching to conventional oil, just be sure to stick to regular oil changes as recommended for synthetic oil (every 10,000 km). In any case, 5W-30 as stated on the cap should work, but it’s always a good idea to consult a mechanic if needed. You can check www.supertechperformance.com if you are interested in other spare parts.
crashboombang is offline   Reply With Quote
Old 04-18-2025, 02:41 AM   #3
AbsoluteFrustration
Drives: 2007 Hatchback
Respectfully, can I ask why you want to stick with conventional?
AbsoluteFrustration is offline   Reply With Quote
Old 04-20-2025, 02:39 PM   #4
romram
cheaper, keeps maintenace every 5k.
also if synthetic will be 0w20, i rather stick with 5w30
any thoughts? suggestion?
appreciated.
2ZR Turbo Yaris 06YarisRS Forced Induction Forum 562 08-28-2025 02:49 AM
Synthetic oil. Can it Really Go 10,000 miles? bronsin DIY / Maintenance / Service 20 08-21-2017 06:37 PM
my first DIY oil change since 1988 justanotherdrunk DIY / Maintenance / Service 15 03-01-2017 10:58 AM
Is it safe to change from synthetic oil to regular oil hero General Yaris / Vitz Discussion 18 02-21-2010 10:51 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
