Old 05-16-2025, 08:48 PM   #1
croustian68
Drives: Yaris LE 5dr 2016 AT Blue
Question MAF 1NZ-FE
i want to put a cone filter instead the kleenex oem one...
I have to bought a MAF adaptor to get solid mounting (cuz the oem is in rubber) so i have to take precise mesurement for buying the right adaptor
Im not 100% sure but it might be
31mm hole diametre for the sensor
55m center to center for the screw
and about 70mm diameter of the piping it self
Im i getting wrong about those spec
croustian68 is offline   Reply With Quote
Old 05-28-2025, 03:30 PM   #2
EPP
Drives: Yaris T-sport 2001
I 3d printed one for my T sport. post a pic of your engine bay and ill tell you if the model i made fits
EPP is offline   Reply With Quote
Old 06-06-2025, 10:40 AM   #3
seanstrong_
Drives: 03 Yaris T Sport (Pink Vitz!)
It's 57MM internal diameter IIRC. You can cut up the stock airbox to use the MAF section.
I've attached an image from Yaris Club UK Facebook Group.
seanstrong_ is offline   Reply With Quote
Troublesome MAF Sensor Circuit Low code woodamsc DIY / Maintenance / Service 4 10-13-2024 09:56 PM
Car will not idle after MAF relocation G.Chetcuti General Yaris / Vitz Discussion 13 02-19-2019 12:34 PM
New O-ring for MAF sensor komichal DIY / Maintenance / Service 3 10-23-2017 08:59 AM
Yaris '99 MAF sensor location. MrNinety DIY / Maintenance / Service 0 11-04-2014 10:12 AM
Recommendations on Mass Air Flow Sensor (MAF) dyslexicanaboko Performance Modifications 11 02-08-2011 10:24 PM
