Old 03-17-2016, 08:31 PM   #217
LTHatch
Drives: 2013 Yaris Hatchback L
From looking over a buddies EG hatch wth a k20 w/6speed, you'd have to get custom everything. Notch the frame rails, new mounts, new exhaust manifold, radiator relocation, new axles, new throttle pedal, modified fuel system, modified harness to fit Yaris cluster etc.
LTHatch is offline   Reply With Quote
Old 03-17-2016, 08:49 PM   #218
MugenRep
iQ innovator & researcher
MugenRep's Avatar
Drives: 2012 iQ
Originally Posted by Frank the Tank View Post
What would be needed in order to do a b18c or k20 swap?
I like the idea of having a honda engine with a LSD transmission.
First, ditch the B-series. It spins the wrong direction. K-series spin the correct direction.
Buy a donor K-series. My suggestion is a cheap Base RSX, Ep3, Element, or CRV. You'd be best off with the 02-03 Ep3 as their axles are smaller and fit 4x100 spindles so should be easier to adapt, not to mention their wiring harness is easy to use and adapt. If you need a Helms service manual for wiring, have it in .pdf form,
1. Custom motor and transmission mounts
2. Pre 2000 Honda aluminum half radiator
3. Donor K-series car (for engine, tranny, wiring, immobilizer, matching ecu)
4. K-tuned or other aftermarket shifter box and cables for easy floor mount.
5. Cable operated and modified throttle pedal OR a donor drive by wire ecu and wiring to adapt to the Yaris.
6. Kpro for a drive by wire application OR a 02-04 CRV, 02-05 Ep3, or 02-06 RSX for cable operated throttle.
7. Spindles and strut adaptation from the donor OR custom axles for the Yaris spindles.
8. PATIENCE, MONEY, AND TIME.
If you insist on boost a K20a3 is the cheapest swap and can handle 300whp for s VERY LONG TIME, but one the torque gets over 300wtq k20a3s have a tendency to bend rods. K20a2, K24a2, K24a2, K24a4, K20z1, K20z3, and K20a (02-06 ITR or JDM Ep3R) can all handle LOTS power with the only problem being compression and detonation risk on the higher compression K20a2, K20z1, K20z3, and the K20a (11.5:1).
I'm sure I'm forgetting things. This is just off the top of my head stuff as a Moderator of Ephatch.com.
MugenRep is offline   Reply With Quote
Old 02-19-2024, 09:04 PM   #219
Emesagaday
Drives: Man
Send a message via AIM to Emesagaday Send a message via Yahoo to Emesagaday
What are the key considerations and modifications needed for a successful B18C or K20 swap into a Yaris, and are there any specific challenges associated with each engine choice?
Emesagaday is offline   Reply With Quote
Old 06-10-2025, 02:58 PM   #220
EPP
Drives: Yaris T-sport 2001
anyone have the dimensions of the enginebay on a p1?
saw a Saab Turbo swapped corsa and i thought maybe? i mean 250-300 whp would be stupid but fun.
EPP is offline   Reply With Quote
Official POLAR WHITE yaris thread wushumasterku Photo-Video-Media Gallery 477 08-27-2023 04:01 AM
