![]() Drives: 2015 blue Yaris Join Date: Jan 2024
High rpm, poor mpg
Hi everyone, I have a 2015 Yaris hatchback base with about 58k on it. I've had it for over a year and the most recent full gas tank averaged about 20.5mpg (I always fill the tank full and reset my trip A odometer to calculate). I don't ever remember it being this bad a year ago. It was maybe 30mpg then, with little changing in driving style between then and now.
My wife reports that when starting from a complete stop that barely touching the pedal will result in what feels like "flooring it" with the rpms shooting up to shift out of first gear. I'm thinking this is the reason for the bad mpg. But resetting the computer didn't do it and the Yaris doesn't seem to be learning and getting any better. I checked engine compression and it was 170psi with little variation between cylinders. The spark plugs did not show any evidence of fouling. Long term fuel trim is -10%. I replaced the downstream O2 sensor about 6 months ago with a Denso to fix a separate CEL and that fixed the issue back then. No CEL now. The engine air filter looks clean, and I cleaned the MAF sensor about a year ago. The rear brakes are definitely not dragging. The fronts' friction seem normal resistance considering the drivetrain attached. The alignment is spot on, and the tire pressure is right. Has anyone had something similar? |
After 10 min of idling the coolant temp was just under 180F. I measured the upper radiator hose at an inside bend in the hose and it was 120F. I measured the lower radiator hose at a similar inside bend in the molded hose and it was 80F. So it seems the thermostat is staying closed when it should.
| Auto high beam mode doesn’t work… | baseballfan416 | Third Gen Yaris General Discussion | 0 | 10-02-2023 11:21 PM |
| 2007 ac swap, will update untill finished/solved | sh0rtlife | DIY / Maintenance / Service | 32 | 06-21-2022 02:01 AM |
| LOW RPM @Idle speed = Bad Volt Generation? | jp_costarica | General Yaris / Vitz Discussion | 4 | 06-14-2012 04:56 PM |
| Yaris sedan low and high beam | jorizk | DIY / Maintenance / Service | 10 | 03-02-2010 09:49 AM |
| Increased MPG or HP anyone???? | slvryaris | Performance Modifications | 55 | 05-27-2007 10:49 AM |
