Drives: 2008 Toyota Yaris Join Date: Nov 2025
2008 Toyota Yaris – Cranks but Won’t Start After ECM Replacement
Background:
Vehicle originally ran but had a rich fuel mixture issue after completing a head gasket and timing chain/guides/gears replacement. Over the course of troubleshooting that problem, the following parts and components have been replaced or tested: --- Parts Replaced / Work Done Head gasket Timing chains, guides, and gears Spark plugs Ignition coils Fuel injectors Fuel pump Oxygen sensor (upstream) Mass Air Flow (MAF) sensor ECM (replacement unit from Flagship One) Relay/fuse block on driver-side fender (replacement made, but no change) Battery terminals and grounds cleaned (including G101/G102 at radiator support) --- Electrical & Diagnostic Testing Verified 12V power and ground at OBD2 connector Verified ~2.5V on CAN high/low lines (pins 6 and 14) Tested resistance between MAF connector and ECM connector for continuity – good Checked all underhood fuses and relays for power on both sides – all good Check engine light illuminates with key ON (indicating ECM is powered) Verified power at ignition fuses in dash and underhood fuse panels Cleaned and re-secured multiple ground connections (battery, chassis, radiator support) --- Symptoms Engine cranks but does not start No fuel or spark output detected OBD2 scanner fails to auto-detect VIN and cannot connect to ECM directly Some other modules (like ABS/body) show partial communication Check engine light still turns on with ignition (suggesting ECM has power but may not be communicating) Tried both ECMs (original and replacement) — same result |
| Toyota Yaris gs mk1 x reg won't start | Inteltech | DIY / Maintenance / Service | 29 | 03-04-2017 07:28 PM |
| 2008 Toyota Yaris Cigarette Lighter Replacement | Kellieparenda | DIY / Maintenance / Service | 0 | 08-02-2015 07:05 PM |
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 08:01 PM |
