Old 05-21-2007, 08:35 PM   #1
driver centric
I know right?
driver centric's Avatar
Drives: 07 Bayou LB
DF210 strange noises
I've had my DF210s installed for about a week and I've noticed when I go over large humps or disturbances in the road, I hear a somewhat loud clank or thumping noise coming from the front of the car. I've checked the bolts and nothing looks loose, has anyone else noticed this? It only seems to happen when the suspension is unloaded and then quickly recompressed. If I just hit a small bump or pothole I don't hear anything but earlier today I was going down a somewhat steep hill and heard the noise when I reached the bottom and the suspension was compressed. Could it be because the springs are shorter than the stock pieces? Any ideas? Thanks for reading.
-Kev
07 Bayou Blue Liftback 5-spd manual
driver centric is offline   Reply With Quote
Old 05-21-2007, 08:44 PM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
most likely it's chatter, I notice it from the rear with my springs, that's my guess
I thought you sold those to chino
SPONSORED BY
Old 05-21-2007, 09:39 PM   #3
driver centric
I know right?
Drives: 07 Bayou LB
Never heard it from the rear but I guessed it might have something to do with the springs being shorter than the stock ones.
I ended up just holding onto them because it was going to be tough to find time in our schedules where we could drive all that way to complete the sale.
-Kev
Old 05-21-2007, 09:42 PM   #4
brickhardmeat
Lonesome Cowboy
I am sure you are much happier with the look and ride of the car with the new springs 'eh? Did you put the wheels on too?
SPONSORED BY
Old 05-21-2007, 10:45 PM   #5
YamilR
YamilR's Avatar
did you cut the bump stops?
Old 05-21-2007, 11:02 PM   #6
whoguy
Drives: Yaris YRS Sedan
When the car is on a jack, are the springs fully captured?
Could be a small amount of play is happening when totally uncompressed.
whoguy is offline   Reply With Quote
Old 05-22-2007, 01:24 AM   #7
did you pita wrap the springs with the black rubber-like thing?
Old 05-22-2007, 07:35 AM   #8
dayvit_h
dayvit_h's Avatar
Drives: 07 Yaris 3Dr
I installed df's on my car and my wifes car with no issues. No bump stop cutting BTW. Did you apply proper torque to all your nuts and bolts?
dayvit_h is offline   Reply With Quote
Old 05-22-2007, 03:02 PM   #9
BokChoi
Mada Mada Dane...
BokChoi's Avatar
Drives: Toyota Yaris LB
after installing my nf's i heard this high pitched screeching noise, but i doubt this is the same problem. anyways the dust guard was bent and making contact with the rotors.
My Car
My Garage
BokChoi is offline   Reply With Quote
Old 05-23-2007, 07:03 PM   #10
driver centric
I know right?
Drives: 07 Bayou LB
brickhardmeat: Yeah I installed everything, I am much happier with the look but would like to find out the source of this noise.
YamilR: Yes, I cut the bumpstops just like in Chris07LB's how-to.
whoguy: I haven't checked that but that's what I'm thinking.
Kaotic: My springs did not come with that, and I think Tanabe was only including them for the rear. My rears already had a length of black tubing on the springs that I guess Tanabe has started putting on so people don't have to wrap that rubber stuff on there themselves.
dayvit: I'm pretty sure I did and I've gone back to check, everything still seems to be torqued down. I had a similar problem when going over bumps after Tanabe coilovers were installed on my Scion xB (almost identical suspension setup as the Yaris) and it was because the top shock tower bolts were starting to back off. So that was the first thing I checked when I heard this noise, but everything seems to check out...
Bokchoi: I remember reading your thread, I don't think this is the same sound.
-Kev
Old 05-23-2007, 07:07 PM   #11
brickhardmeat
Lonesome Cowboy
The Tanabe DF210's I sold to a local here because I'm getting coilovers also came as you say without vinyl and only the rubber secured on them. Funny thing is the instructions for applying the wrap were in the box.
I hope you get this figured out.
SPONSORED BY
Old 05-24-2007, 09:40 PM   #12
driver centric
I know right?
Drives: 07 Bayou LB
Checked the top bolts tonight, they're snug. I didn't have an allen key to use in there like Chris' how-to...could that mean they're not really as tight as they need to be? I got them tightened all the way down until the shaft starts spinning.
-Kev
Springs - Tanabe DF210 or Tein S Tech andylai2k Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 06-10-2007 09:22 PM
How to block Wind Noises? jamal1984 General Yaris / Vitz Discussion 9 04-12-2007 12:05 PM
df210 OxyG3nE Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 08-15-2006 06:04 PM
TANABE DF210 SPRINGS AVAILABLE!!! C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 08-05-2006 12:28 AM
Squeaks, rattles and noises. Schmingie DIY / Maintenance / Service 100 03-06-2006 09:02 PM
