Old 05-22-2007, 12:49 PM   #109
ChinoCharles
Drives: LB
You have to remember, it is a part that may be spinning at thousands of RPM's when it fails, turning it into a bonafide Dreidel of ultimate despair! I'll bet the side of his block is all jacked up too!
Not a part to skimp on if you ask me.
Old 05-22-2007, 02:09 PM   #110
tk-421
tk-421's Avatar
Drives: 5D-07-LB
OK... I guess I'm convinced. Now all I need to know is wether I should wait for the pulley set to come out or not. Sure, I understand that it's better to support our vendors ASAP so they can come out with products sooner and allathat, but I'm kinda wary about messing with the motor too many times.
I would much rather install the whole set once and be done with it.
Old 05-22-2007, 02:58 PM   #111
kurokoma-kun
Drives: 2007 Yaris HB
...bonafide Dreidel of ultimate despair!
AHAAHAHAHAHAHAAAAHAA you are funny mofo chino
Old 05-22-2007, 09:31 PM   #112
MudBug
Drives: 07 Yaris
Installed mine today and the first thing I noticed was that it idles at higher RPMs than it did.
I didn't notice the idle being rough.
It does seem like the shift is smoother now (AT).
MudBug is offline   Reply With Quote
Old 05-31-2007, 02:18 PM   #113
ChinoCharles
Drives: LB
NST @ SCION EXPO 2007
Old 06-02-2007, 03:46 PM   #114
ok, I'm in!
Just ordered from Dezod.... hope you have red, 'cause the website didn't say "no"....
Old 06-03-2007, 03:30 AM   #115
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
I will be definatly ordering the full set, (Crank/WP/Alt.) pulleys when they come out, Red all the way.
Do we estimate how much HP we will get with the full set?
Old 06-03-2007, 06:00 AM   #116
Nigal
Nigal's Avatar
I was looking at the pullies in my car the other day while changing oil. How hard is a pully set to install? It looked reeeeeal tight in there. I don't think I could fit my big dickbeaters in there to do it.
Old 06-03-2007, 07:51 AM   #117
tk-421
tk-421's Avatar
Drives: 5D-07-LB
A simple search in the DIY forum will turn up this:
http://www.yarisworld.com/forums/showthread.php?t=3964
Good luck!
Old 06-04-2007, 08:09 PM   #118
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
is it going to be less expensive to buy it in a set or its the same to buy it appart;..
OxyG3nE is offline   Reply With Quote
Old 06-05-2007, 07:04 AM   #119
nigel
Drives: yaris
does the pulley work on other car with 1nz FE engine?
my dad also want to get one for his corolla with 1nz fe engine
nigel is offline   Reply With Quote
Old 06-05-2007, 11:43 AM   #120
sdmf
Down With the Sickness
sdmf's Avatar
Drives: 2007 yaris liftback
Send a message via AIM to sdmf
arent the corolla's powered by 1zz fe's? but the asian corolla is 1.6L
Strength - Determination - Merciless - Forever
sdmf is offline   Reply With Quote
Old 06-06-2007, 03:00 AM   #121
sdmf
sdmf's Avatar
bump, i want my alt. and water pump pulley already
with nst quickshifter
Old 06-06-2007, 07:19 AM   #122
nigel
Drives: yaris
check this out
http://toyota.com.hk/showroom/corolla_cbu/index.html
Old 06-06-2007, 01:54 PM   #123
I am told these are back ordered until July 1.... boo!
I'll wait tho....would never ever order "that other company's" pulley
Old 06-06-2007, 02:20 PM   #124
sdmf
sdmf's Avatar
wow, now i know know
Old 06-06-2007, 05:24 PM   #125
NonStopTuning
Hi again everyone,
Wow, it looks like there has been a lot of good discussion here lately. This is turning into a very productive thread with some great information.
Here is a little info regarding fitment on the 1.5, 1.3, Yaris, Corolla, etc. There are two versions of the 1NZ crank pulley...
One version, on cars with NO power steering pulley, is a SINGLE-ROW Crank Pulley.
Example: USDM Toyota Yaris 1NZFE... Just one row there...
Another version, on cars equipped with a power steering pulley, is a TWO-ROW Crank Pulley.
Example: Scion xA and xB 1NZFE... See the two rows there?
Those of you with a USDM Yaris, and those internationally who have SINGLE-ROW Crank Pulleys can order pulleys from our Yaris page on our site...
http://www.nonstoptuning.com/pKitToyYarisPics.htm
Those of you internationally, and those with TWO-ROW Crank Pulleys can order pulleys from our Scion xA page on our site...
http://www.nonstoptuning.com/pKitToySciXAXB.htm
As always, thank you for all your support and enthusiasm. I don't post on any other forums, but I really do enjoy visiting your forums from time to time
MIKE @ NST
www.NonStopTuning.com
Old 06-06-2007, 06:29 PM   #126
can you confirm that they are back ordered until July 1?
