![]() Drives: 2007 yaris 3dr ce Join Date: Jun 2007
high pitch whine at 100km/h
I started getting this last night. When I get to, or very close to 100km/h there is a high pitch whine coming from the engine, or somewhere in the front end. As soon as I lay off the gas it stops, but starts again when I hit the gas. Has anyone else experienced this. Does anyone know what this could be?? I have just over 1000km's on the car if this helps.
i've never experienced this.
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Is it only at 100km/h, or does it start there and sustain above that speed?
Can you determine if it is from the engine, transmission or steering/suspension/wheels? Is it a mechanical whine, or an air movement whine?
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
It is not from the air movement, it is defitnetly mechanical. It is not ear shattering, but it is there. It sounds like it is coming from the front of the vehicle. I am assuming the engine because the second I lift my foot off of the gas it goes away, and comes back just as quick when I hit the gas again. Starts there and sustains it(from 100km/h).
do you have a power adapter plugged in? sometimes you get a whine in the speakers from the motor during high rpm.
07 Yaris LB 5spd AE86 Corolla GTS 5spd http://microimage.ning.com/ http://www.microimageonline.com/store.html |
yes, I'm thinking electrical interference causing the whine in the speakers, very common thing to happen...
GIGA...DRILL...BREAKER!!!
Drives: Lagann. ;P Join Date: Feb 2006
Ion flux capacitors. They always kick in just before the thermal couplings engage, which reduces the quantum-level stress on your frame. Nothing to worry about!
~YR
Be polite. Be professional. But have a plan to kill everyone you meet.
#8 | |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Yaris HB Join Date: Apr 2007
or a phaser on overload, have you checked all the ventilation ducts?Seriously though, could it be a belt slipping? Or does that only happen at low speed? |
#9 | |
![]() ![]() Drives: 2007 5-Door Hatchback Join Date: May 2007
When I was trying to destroy my engine by driving in third instead of drive (um, not on purpose *cringe*), it would get noisy at 100km/h. No high pitched whining, though. You're sure you're in the right gear?
| DIY - HID Retrofit | Violin | DIY / Maintenance / Service | 57 | 06-11-2007 06:17 PM |
| Tranny Whine | jmjonesey | DIY / Maintenance / Service | 11 | 05-23-2007 10:32 PM |
| Why do all low profile tires have to be of high performance design? | grampi | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 05-16-2007 01:23 AM |
| High pitched whine using stock head unit / aux input? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 02-02-2007 12:49 PM |
