Old 06-23-2007, 11:26 AM   #37
smokinyaris
smokinyaris's Avatar
Drives: bad boy
to clear BBK what size wheels do we need to run on our Yari..........
smokinyaris is offline   Reply With Quote
Old 06-23-2007, 11:41 AM   #38
ChinoCharles
Drives: LB
Anyone know how much the Wilwood and/or Greddy BBK's go for?
Old 06-23-2007, 03:01 PM   #39
03Z33
03Z33's Avatar
Drives: TCR10
This will depend on which brake kit or rotor size you use, but most of the existing brake kits on the market will clear most 15" wheels.
The Greddy kit retails for $1850 but it doesn't fit the Yaris. They had a typo on their website a while back, but it's corrected now. The kit will only fit Echo, Xa/Xb.
I haven't seen any Wilwood "kits" on the market, only a couple of people do self made ones...
03Z33 is offline   Reply With Quote
Old 06-23-2007, 03:25 PM   #40
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Fab up a backing plate that can accept a 2.5 inch hose and get some front fog light bezels. Run hose from the bezel directly to the rotor hat. That will help curb brake fade. This can cool rotor temps as much as 600 degrees.
Here is the setup on my Cobra. I have zero fade with an agressive street pad at Streets of Willow.
Old 06-23-2007, 03:34 PM   #41
ChinoCharles
Drives: LB
Thank you for the clarification!
Ashley, nice setup!
Old 06-23-2007, 03:45 PM   #42
largeorangefont
Break'em off some.
Ashley, nice setup!
Thanks,
Try some brake cooling before spending big bucks on a brake upgrade. The stock calipers seem decent. With SS lines good pads, fluid and some sort of cooling setup the stock calipers would probably be fine for 99% of the track whores out there.
Old 06-23-2007, 04:59 PM   #43
smokinyaris
Drives: bad boy
thanks for the info brotha's
Brake Shopping drell42 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-12-2007 01:25 AM
Removing third brake light lightyearsgirl DIY / Maintenance / Service 8 08-06-2006 12:26 PM
cheap trd big brake kit *joke* birdy Off-topic / Other Cars / Everything else Discussions 3 06-13-2006 01:04 AM
