Old 06-26-2007, 04:37 PM   #19
Kunst1
Drives: 2007 Yaris LB
Your Vitz appears to have a CVT rather than a 4-speed auto. I read at some Japanese sites that 'S' stood for 'Sport' and it will keep the engine RPM higher, and 'B' stood for 'engine Braking' - equivalent to low gear.
Kunst1 is offline   Reply With Quote
Old 06-26-2007, 11:08 PM   #20
apples
Drives: Yaris 2006
Really?? Thanks!
apples is offline   Reply With Quote
Old 06-29-2007, 01:24 PM   #21
apples
Drives: Yaris 2006
OK, S is not sport.
Wikipedia says S is the same as '2'.
So now what is B?
Old 06-29-2007, 01:30 PM   #22
bearda
bearda's Avatar
Drives: 2006 Mazda3 Sedan
Originally Posted by apples View Post
OK, S is not sport.
So now what is B?
Got a link to that?
bearda is offline   Reply With Quote
Old 06-30-2007, 01:57 AM   #23
B is probably the lowest gear, which would be "1".
Old 06-30-2007, 02:18 AM   #24
Edd
Drives: None
B - braking (1st)
S - steep (2nd)
Here's an easy way to work it out (if you have a tach). Rev to 2500 rpm and look at the speedo for each, write it down (when you're stopped obviously ) and let us know. From that we can probably work out what gear it is limiting to.
Edd is offline   Reply With Quote
Old 06-30-2007, 02:26 AM   #25
yup, or if he has a tach, put in "B" and see where it redlines. basically another way of doing what edd said.
Old 06-30-2007, 02:42 AM   #26
apples
Drives: Yaris 2006
It doesn't have a tach.
Old 06-30-2007, 03:34 AM   #27
oh, that's going to be hard then...ummm, you can try to leave it in "B" and press the gas pedal 1/4 or 1/2 way down and see if your speed becomes constant, then switch to "S" with your pedal at the same spot (don't take your foot off, keep it where it is on the pedal throughout the entire time) and see if your speed goes up. if it does then maybe "S" is second gear and "B" is first. i'm not sure about this tho.
Old 07-01-2007, 01:36 PM   #28
apples
Drives: Yaris 2006
i went on 20 mi/h on B but it started making a lot of noise. i don't want to blow my engine. :p
Old 07-01-2007, 05:11 PM   #29
yea, that's most likely first. at 20 mph in my car in first, the rpm's in the high end.
Old 07-01-2007, 07:35 PM   #30
Edd
Drives: None
Yay, now do the same in S.
Old 07-02-2007, 01:20 PM   #31
apples
Drives: Yaris 2006
S is 2. That's what wikipedia says.
Old 07-02-2007, 02:41 PM   #32
you should also try to find a more credible site. anyone can put up anything on wikipedia. i can go there and say that "S" is 1...but it sounds right. so "B" is 1, and "S" is 2.
Old 07-02-2007, 03:08 PM   #33
Meteorite Man
Passin' The Gas...Station
Meteorite Man's Avatar
Drives: Same As You But Different
Send a message via Yahoo to Meteorite Man
Ok, by looking at your location you are in California. The gateway to the US from Asian countries. You're telling us that there isn't ANY way you can find a local Japanese Car Club, BookStore,Grocery Store or Library where someone can translate this for you? How about a Translation WebSite? Punch it in and you should get fairly close to what you want. Gotta do some legwork on this one. It's not gonna fall out of the sky.
Any colleges around? You may have to drive a few miles if for some reason they aren't ACROSS the street. Who knows, by the time you get there you might of already figured out how to drive this car. hmmmmmmmmmmmmmm?
This might of been the homework BEFORE the test?
Good Luck
Chuck
MY Gas Station Attendant Misses Me...
Chuck
Meteorite Man is offline   Reply With Quote
Old 07-04-2007, 09:29 AM   #34
apples
Drives: Yaris 2006
you mean a hunt for a japanese.
I wish i had time, but unfortunately these days I have a tight schedule. And I can't use a translator because my windows doesn't support Japanese.
Old 07-04-2007, 10:25 PM   #35
Meteorite Man
Hunt? Hmmmm..Probably a better word than that but yes, that is what you may have to do. Crack open the yellow pages, white pages, local newspapers.
It's there if you want it. I'm sure you did a bit of work to get the car here. I'd bet it is less work to get this worked out.
Keep trying...
Chuck
Chuck
Few questions mystikdynasty03 Cosmetic Modifications (Exterior/Interior) 3 05-01-2007 08:42 PM
Lowering Springs - Questions ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 01-10-2007 09:21 AM
Questions on pricing littlecarlove New YARIS Purchase Forum 17 10-29-2006 08:53 PM
Questions, questions... littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-21-2006 02:42 PM
Newbie questions about the 2007 Yaris urabus General Yaris / Vitz Discussion 11 07-06-2006 12:32 PM
