Old 06-30-2007, 12:09 PM   #37
RUBBERDIPSTICK
Drives: Toyota Yaris Base Sedan
Originally Posted by brickhardmeat View Post
what is your side wall? I would suggested running the correct tire pressure, that sounds high
the less side wall you have the lest cushion you have, hence the larger the wheel the less side wall you have room for
My tires are 215/40ZR17's and the recommended pressure is 35. I'll take it down to that pressure to see how it feels. Just don't want to dent the rims. How common is this? Think I should be worried?
RUBBERDIPSTICK is offline   Reply With Quote
Old 06-30-2007, 12:22 PM   #38
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
any rim can be bent slamming into a pothole, you are more likely to bend a rim when you are running a lower side wall, way more likely
dodge potholes
don't run you tire pressure to high, it is dangerous
keep pressure between 30-35
SPONSORED BY
Power upgrade (pictures). W.A.S.P DIY / Maintenance / Service 91 11-15-2017 10:32 PM
Finally! KittenRD New YARIS Purchase Forum 6 01-01-2007 09:16 PM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 04:24 PM
