Old 07-16-2007, 04:49 PM   #1
mandriu
11b1p
mandriu's Avatar
Drives: yaris s
Question electric water pump help!
Well I decided on the Meziere wp136. it's "universal". The problem is that I don't know which direction the coolant flows. From the lower hose to engine or from engine to lower hose. I will be putting it in this weekend, but don't know which direction.
I appreciate any help.
mandriu is offline   Reply With Quote
Old 07-16-2007, 07:30 PM   #2
Shijima
Drives: 07 HB
Im assuming so he has one less thing for the engine to move.
Shijima is offline   Reply With Quote
Old 07-16-2007, 07:47 PM   #3
joey1320
joey1320's Avatar
Drives: Yaris LB
hot coolant goes thru the thermostat into the radiator. so if the lower hose has the thermostat(?) then is from the hose to the engine. if its on the top hose then from the engine to the hose.
http://auto.howstuffworks.com/cooling-system2.htm
and why are you doing this again? to free up some horsepower and better fuel economy???
joey1320 is offline   Reply With Quote
Old 07-17-2007, 12:20 AM   #4
mandriu
11b1p
mandriu's Avatar
Drives: yaris s
joey1320
I was kind of thinking that but didn't want to dive in.
So far I have about $230.00 invested in the project. There are a number of Electric water pumps. all over $170 I really think that taking the water pump off of the belt will free up 1-5 whp. btw, that is about the price of a good cai. The only real concern i have now is that there will be about 1" of clearance on all sides.
Old 07-17-2007, 01:17 AM   #5
churp
Clean and (dis)Functional
churp's Avatar
Usually the hot coolant from the engine always goes to the top of the radiator....this is because the hottest coolant stays in the top of the radiator(hot liquid lighter than cold), as it cools the liquid sinks to the bottom of the radiator and returns to the engine. Can't recall seeing it any other way.
____________
Old School Cobble Jockey
Old 07-17-2007, 01:30 AM   #6
mandriu
11b1p
mandriu's Avatar
Drives: yaris s
The Thermostat is on the lower hose. per CO-17 yaris manual here at yarisworld. That is what is confusing me. I guess on saturday after About one beer I will remove the upper hose at the radiator and crank the engine to see which side spews. then adjust accordingly
Old 07-17-2007, 02:29 AM   #7
Yeah that's what I see from the manual too, the inlet to the pump is there, so you should just trace the hose to see where it's connected to...
Old 07-17-2007, 07:56 AM   #8
joey1320
joey1320's Avatar
Drives: Yaris LB
good luck with the project. keep us updated.
Old 07-17-2007, 10:29 AM   #9
03Z33
03Z33's Avatar
Drives: TCR10
I'd consider running some kind of warning light into the cabin to let you know when the pump is actually running, just in case it stops working for any reason.
Old 07-17-2007, 10:50 AM   #10
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Every car I have ever worked on dumps hot coolant out the top hose and pulls cooled coolant in through the bottom hose. I guarantee it is the same on the Yaris... Toyota puts the thermostat on the engine side of the lower hose on many engines, but they still flow the same direction.
Old 07-17-2007, 10:56 AM   #11
mandriu
11b1p
mandriu's Avatar
Drives: yaris s
that's a good idea about the warning,Maybe some kind of L.E.D. on the circuit. I am pretty confident that the pump will function fine. The only reason I say this is that the pump company is known in the Hot rod market to work.
Old 07-17-2007, 11:56 AM   #12
WRBlue
Drives: Yaris 3 Door, 04 WRX, 69 Lotus
Then theres the cavatation at high rpms with a belt driven pump. An electrically driven water pump will always cool more evenly than a belt driven pump. A cooler engine performs better than a hot engine (but a hot engine is more efficient with fuel use).
What are you doing about the OEM pump?
As for warning lights... You already have one, the H2O gauge ;)
WRBlue is offline   Reply With Quote
Old 07-17-2007, 12:32 PM   #13
AlphaFox
AlphaFox's Avatar
Drives: 07' Yaris Liftback - silver
get a scanguage, it will show you actual water temps. cool to watch!
AlphaFox is offline   Reply With Quote
Old 07-17-2007, 02:25 PM   #14
mandriu
11b1p
mandriu's Avatar
Drives: yaris s
I don't have the scanguage, but i have an obd2 that reads all the good stuff.
This is a more accurate account of expenses so far..
Water pump 186.50
2 x hose fittings 15.99
1 belt 377k4 8.99 (measured with string)
relay mr44 5.99
hose clamps 1.99
wire and ends 10.00
total 245.00 +-change
I will leave the OEM pump in place for now. I will remove the pulley. Later I will purchase a new gasket for a pattern and a sheet of 1/4" aluminum. Then Dremel and drill a cover.
Old 07-17-2007, 04:22 PM   #15
jdium
Mr Attitude
jdium's Avatar
Drives: Blazing Blue 5 Spd
This is a very interesting mod, actually seems worthwhile. As for the blockoff plate, maybe it could be used as your mounting point for the electric pump? Also, a good shop (like the 1 I work at) could make your plate for you very easily. If you have the patience and knowledge to create a good CAM file for what you need, a good sheetmetal shop could pop one out laser cut in minutes...maybe even to stuff like tap and countersink for you...just an idea. And once the hard part is done, you can maybe make some money selling them...
It's scary to think that half the people surrounding you are below average...
jdium is offline   Reply With Quote
Old 07-17-2007, 07:31 PM   #16
Jerkratt
Jerkratt's Avatar
i would be interested in this water pump... i dont know if u mentioned the company.. and what type
EDIT: nm first post lol disregard that
"It hurts more when its wet"
Old 07-17-2007, 09:40 PM   #17
AlphaFox
AlphaFox's Avatar
A dyno before and after would be good, to see if it actually does anything
Old 07-21-2007, 02:13 AM   #18
xxcanuckxx
Drives: 2015 SE HB
is he still under his car? this sounds like a good idea...
xxcanuckxx is offline   Reply With Quote
Drinking from the black pump XOG Performance Modifications 1 04-20-2007 05:49 PM
sum dude asked if my car was electric... Blenjar General Yaris / Vitz Discussion 17 01-12-2007 10:39 PM
what water temp does cooling fan turn on gonzo452001 General Yaris / Vitz Discussion 10 11-07-2006 05:50 AM
[Detail] [as to make ] Auto Laudering Sérgio Barros Wash, Wax, Detailing, Exterior Repairs 4 08-22-2006 03:56 AM
